Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Adding Negative Camber?
Old Dec 3, 2001 | 10:00 PM
Padawan's Avatar
Darth ModerVader
Default Adding Negative Camber?
I figured this would be the best place to post this question. What kits are available to add negative front camber to the DC2 chassis? I know most camber kits are intended to reduce negative camber, but do any allow for adjustment in both directions? Thanks.
Old Dec 3, 2001 | 10:09 PM
Chris's Avatar
Default Re: Adding Negative Camber? (SpecR0123)
http://www.kingmotorsports.com/products/king/
Old Dec 4, 2001 | 04:40 AM
Albino Dragon's Avatar
Skunk2 also makes the adjustable A arms and rear trailing arms very similar to the king pieces but much cheaper.
Old Dec 4, 2001 | 05:25 AM
typer_801's Avatar
Default Re: Adding Negative Camber? (Albino Dragon)
You can also swap the upper control arms (left to right, right to left) to gain camber and caster in the DC2's. This mod was discussed at length in a post about a month ago.
Old Dec 4, 2001 | 09:13 AM
WRXRacer111's Avatar
Default Re: Adding Negative Camber? (typer_801)
Jeff, did that actually pick up camber, or just caster?
You could also take a look at the SPC pieces at http://www.specprod.com
and the K-Mac units at http://www.kmacsuspension.com (I think this works)
Both are adjustable balljoint setups, the K-Mac adds a caster adjustment that I do not think the SPC has.
https://honda-tech.com/zerothread?id=44833
take a look there
Old Dec 4, 2001 | 09:18 AM
Crazydave's Avatar
I have the ingalls kit..
I was able to get an additional 1/2 degree negative out of it.. you can slot them and get even more.. or change the bushings
by flipping the plate that ball joint is attached too.. you can change the caster.. but I forgot which way... I'd have to look at it
[Modified by Crazydave, 6:19 PM 12/4/2001]
Old Dec 4, 2001 | 09:25 AM
ghettoracer's Avatar
Banned
From: at last finally back to sweet home, sunny north cali, usa
Default Re: Adding Negative Camber? (Chris)
if i'm not mistaken those black A arms shown were z.speed's which was the old lable of group-a prior to skunk2, which was skunkworks. it had the older aluminum slider plate.
the new ones has more adjustment range and uses a much thicker/stronger steel plate. the new ones comes with less parts, only the A arm and slider/balljoing, that's why the pricing was lowered.
i have the EG/DC pieces in stock if anyone needs them. EK's are on backorder. adjustement range is about +/- 4 deg. from the center. plenty of range for full adjustment.
Old Dec 4, 2001 | 01:44 PM
Padawan's Avatar
Darth ModerVader
Default Re: Adding Negative Camber? (frank@b16a.com)
How much do those A arms run? Also - how much, and in what direction, does the caster change by switching the upper control arms?
Old Dec 5, 2001 | 03:23 AM
Banned
they are $200 for the pair. but i've got a deal going for them email me privately... switching the control you'd have to check the other threads I think Roger said around 1.5 deg?
CivicSiRacer
27
Apr 14, 2015 05:26 AM
ever'sneighborhood
10
Mar 2, 2010 03:31 PM
Bull
Feb 12, 2004 02:47 PM
Mike B
Apr 18, 2002 03:41 AM
DanHill
Feb 28, 2002 10:09 AM
