Performance General Performance oriented Parts (Ex: Camshafts, Electronics, Air Intakes, Exhausts, complete engines)
Vibrant Performance Products
Old Sep 12, 2010 | 12:58 AM
RedlineMotive's Avatar
Default Vibrant Performance Products
Vibrant Adjustable Timing Belt Tensioner
Designed and tested by the VibrantETD Racing Factory Race Team for use in competition on our AllMotor Honda CRX drag car Designed to reduce timing belt slack for more accurate valve timing thereby im ...
Vibrant Aluminum Catch Can
Vibrants new universal Aluminum Catch Can is the first to offer a modular design The length of this catch can is fully adjustable to accomodate the available space in your engine bay The can measure ...
Vibrant Aluminum Piping - 180 deg. U-Bend
T6061 Aluminum 15mm Thick Fabricate your own custom Intercooler Pipe Assemblies or Air Intake Kits High Luster Polish Easy to Weld ...
Vibrant Aluminum Piping - 45 deg. Elbow
Vibrant Aluminum Piping - 90 deg. Elbow
Vibrant Aluminum Piping - Joiner Coupling
Vibrant Aluminum Piping Joiner Coupling ...
Vibrant Aluminum Piping - Straight Tubing
Vibrant Aluminum Racing Pedals
T6061 Aluminum Universal Application For Manual and Auto Transmission see notes ...
Vibrant Aluminum Vacuum Distribution Bar
Allows for consistent vacuum from a single source that can be distributed to up to 6 outlet ports to support all of your engine parts that require vacuum such as Boost Gauges Boost Controllers BlowOf ...
Vibrant Boost Brace Assembly
Vibrants new Quick Release Boost Brace allows for ultra secure worry free joining of intercooler piping They are like an insurance policy to ensure that your IC piping never blows off from the silic ...
Vibrant Cam Gear Caps
For that added touch to your Cam Gears Vibrant offer their Polished Aluminum Cam Gear Caps ...
Vibrant Classic Air Filters
Vibrants THE CLASSIC Performance Air Filters feature a premium 4Ply cottongauze filter elements that provide significantly more airflow than a stock filter while providing excellent filtration of air ...
Vibrant Crankcase Breather Filters
Vibrants Breather Filters feature a premium 4Ply cottongauze filter elements that provide significantly more airflow than a stock filter while providing excellent filtration Perfect for Crankcases or ...
Vibrant Exhaust Fabrication - Blow Off Valve Flange
Vibrant Performance makes it easy to weld Blow Off Valve matting flanges to your induction plumbing Flange kits are now available for mating up to HKS SSQ series and Greddy SRRS series blow off valves ...
Vibrant Exhaust Fabrication - Exhaust Flanges
Thick CNC machined flanges to avoid warping due to high heat T304 Stainless Steel Create your own custom exhaust application with high quality parts ...
Vibrant Exhaust Fabrication - Exhaust Sleeve Clamps
T304 Stainless Steel Allow for quick easy and effective clamping of same sized tubing Numerous sizes from 225 to 3 OD ...
Vibrant Exhaust Fabrication - Flex Couplings
Vibrant flexible couplings are engineered to isolate vibration generated by your vehicles engine thereby relieving stress on the exhaust system Flex couplings reduce premature cracking of manifolds a ...
Vibrant Exhaust Fabrication - Hanger Rods
Perfect for Custom Exhaust Systems Designed to fit securely inside factory and aftermarket rubber hangers so the exhaust system doesnt move excessively Sold in Packs of 10 ...
Vibrant Exhaust Fabrication - High Flow Catalytic Converters
Vibrant High Flow Catalytic Converters are offered in standard Ceramic Core or RaceBred Metal Core Vibrant Performance Universal High Flow Ceramic Core Catalytic Converters are designed to increase ho ...
Vibrant Exhaust Fabrication - High Temp Exhaust Gaskets
Made from High Strength Flexible Graphite Available in 2 and 3Bolt Style Available is a Number of Popular Diameters ...
Vibrant Exhaust Fabrication - J-Spec Header Flange Kit
The JSpec Header Outlet Flange Kit was designed to make it easy to install Vibrants JSpec Headers or any header with a 25 outletThis kit consists of a 2bolt connecting flange with a flared outlet neck ...
Vibrant Exhaust Fabrication - Manifold Flanges
T304 Stainless Steel 38 Thick Laser Cut CNC Machined Perfect for Custom Manifolds and Headers ...
Vibrant Exhaust Fabrication - Muffler Strap Clamps
T304 Stainless Steel Weld your hanger rods to the strap clamp rather than the muffler to protect the finish of your mirror polished muffler Fits Oval or Round Mufflers ...
Vibrant Exhaust Fabrication - Oil Line Fittings
Vibrant Exhaust Fabrication Oil Line Fittings ...
Vibrant Exhaust Fabrication - Stainless Steel Fasteners
T304 Stainless Steel Perfect for any Exhaust System Order in Bulk or Retail Packs ...
Vibrant Exhaust Fabrication - Standard Resonators
Designed to dampen exhaust noise without restricting exhaust flow Feature Vibrants True Straight Through perforated core surrounded by our premium sound absorption materials T304 Stainless Steel ...
Vibrant Exhaust Fabrication - Turbo Flanges
Designed to use with Common Turbochargers Made from Thick T304 Stainless Steel Perfect for Custom Manifolds and Turbo Kits ...
Vibrant Exhaust Fabrication - Ultra Quiet Resonators
Vibrants Ultra Quiet Resonator utilizes a larger sound absorption chamber for better sound suppression than typical bottle style resontors Feature Vibrants True Straight Through perforated core surro ...
Vibrant Exhaust Fabrication - V-Band Flange Assemblies
VBand Flange Assemblies are a popular and effective alternative to traditional flanged or slip fit tube connections They work very well in operating conditions involving stress vibration and extreme ...
Vibrant Exhaust Fabrication - Wastegate Muffler
Vibrant Exhaust Fabrication Wastegate Muffler ...
Vibrant Inner Muffler Silencers
Direct replacement silencer for Vibrant Mufflers and CatBack Exhausts Baffle measures between 38539 Outside Diameter Check notes for exact measurements ...
Vibrant Intercooler Core
Vibrant Bar and Plate Intercoolers are designed and built to provide superior cooling efficiency and overall durability compared to tube and fin style intercoolers resulting in these cores being suita ...
Vibrant Intercooler End Tank
T6061 Aluminum Designed for Specific Vibrant Cores but may fit other applications ...
Vibrant Mandrel Bent Tubing
Vibrants unique UJ Mandrel Bent Tubing combines a 180 degree bend and a 45 degree bend into one integral unit to give fabricators the ability to get up to 3 seperate bends and a substantial straight l ...
Vibrant Mass Air Flow Sensor Adapters
Perfect for the Custom Intake System Applications for Many Popular Sport Compact Cars T6061 Aluminum ...
Vibrant Open Funnel Filters
Vibrant OPEN FUNNEL Air Filters feature an inverted filter cap design which greatly increases the filter surface area for improved air flow and filtration Available in Numerous Sizes and Shapes ...
Vibrant Parking Brake Boot
100 Real Leather Universal Application ...
Vibrant Parking Brake Handles
T6061 Aluminum Real Carbon Fiber Inserts Universal Application ...
Vibrant Polyethylene Tubing
Flexible lightweight and durable Suitable for Air Lines and Instrumentation Capable of withstanding operating pressure up to 100 PSI and temperatures up to 140 deg F ...
Vibrant Promo Products
Show your Vibrant Pride with Hats TShirts Stickers and MORE from your Favorite Company ...
Vibrant Quick Release T-Bolt Clamps
Designed to fit 213 to 544 Outside Diameter tubing please choose correct part for specific applications Vibrant TBolt Clamps offer Unmatched Clamping Force Say Goodby to Loose Intercooler Piping So ...
Vibrant Sensor Fittings (Bungs)
Variety of Sensor Bungs for Custom Exhaust Applications See Item Notes for More Details ...
Vibrant Shift Boots
Vibrant Shift *****
T6061 Aluminum and Real CF where applicable Universal Application For Auto and Manual Transmission see notes ...
Vibrant Short Throw Shifter
T6061 Billet Aluminum High Luster Polish Designed to Reduce Throw by up to 40 ...
Vibrant Silicone - 45 Degree Elbows
Race Proven Designed for High Temperature High Boost Applications Wont swell or burst under extreme conditions 4 Ply Reinforced Silicone Available in a Number of Diameters and Lengths Available in Bl ...
Vibrant Silicone - 90 Degree Elbows
Vibrant Silicone - Hump Hose Couplings
Vibrant Silicone - Non-Reinforced Silicone Connectors
Available in Blue Red and Yellow Available in Numerous Sizes and Shapes NOT For Boosted Applications ...
Vibrant Silicone - Reducer Couplings
Vibrant Silicone - Reinforced Heater Hose
Vibrant introduces nylon reinforced Silicone Heater Hose that is very flexible and designed to withstand elevated temperatures Temperature Range 65F to 350F Suitable for oil and coolant fluid service ...
Vibrant Silicone - Straight Hose Couplers
Vibrant Silicone - Vacuum Hose (Bulk)
Vibrant silicone vacuum hose is designed to handle the extreme conditions found in high performance engines Will not collapse under high vacuum conditions and dont peel crack or swell like inferior q ...
Vibrant Silicone - Vacuum Hose (Pack)
Vibrant Stainless Butt-Weld Pipes
Schedule 10 Pipes are 25 times thicker than standard 16 gauge tubing making them ideally suited for custom manifold and downpipe fabrication Feature specially machined ends that make them easy to wel ...
Vibrant Stainless Steel Headers
T304 Stainless Steel Available in in 41 421 and Race Header Designs Two Year Limited Warranty ...
Vibrant StreetFlow Air Intake System
Vibrant STREETFLOW Air Intake Systems are designed to produce susperior horsepower torque and throttle response by providing cooler denser air to your motor STREETFLOW Intake tubes are CNC mandrel be ...
Vibrant StreetPower Exhaust Systems
Vibrant STREETPOWER CatBack Exhaust Systems are styled for the street and engineered to performAll STREEPOWER CatBacks Feature 16 gauge T304 Stainless Steel exhaust tubing for superior durability and ...
Vibrant Strut Tower Brace
T606 Billet Aluminum Vibrant Strut Tower Braces are lightweight yet very strong and are designed to eliminate virtually all body flex Ideal for vehicles with stiffened suspensions or larger wheeltire ...
Vibrant TPV Exhaust System
Vibrants TPV Performance Exhaust Systems are Engineered To OutperformAll TPV CatBacks Feature 16 gauge T304 Stainless Steel exhaust tubing for superior durability and exhaust resonance control The tub ...
Vibrant Ultimate Fiberglass Center Console
Complete the transformation of your vehicles interior with The Ultimate Universal Fiberglass Center Console Combine it with our Ultimate Universal Fiberglass Dashboard to take your interior from Mild ...
Vibrant Universal Exhaust Tips
T304 Stainless Steel Available in all shapes and sizes including DTM Style Round Tip Oval Tip Dual and Square Tip Bolt on or Weld on available for your Custom Ride ...
Vibrant Universal Intercooler with End Tanks
Vibrant Universal Muffler - StreetPower
Feature Vibrants True Straight Through perforated internals for unrestricted flow and maximum horsepower These mufflers are densely packed with our premium multilayered sound absorption materials hel ...
Vibrant Universal Muffler - StreetPower Stealth
Fly below the radar with a Vibrant STREETPOWER Flat Black Muffler Its a must for any true Sleeper car 100 T304 Stainless Steel Construction with a high temperature Flat Black coating to help avoid ...
Vibrant Universal Muffler - TPV
Vibrant Universal Mufflers - Race
Tracks all over North America now require racers to install some form of sound reduction equipment on their race vehiclesVibrant Performance Race Mufflers are designed to help reduce noise levels prod ...
Vibrant Universal Oil Feed Kit
All Vibrant Performance Oil Feed Kits include a Teflon lined Stainless Steel flexible hose and high quality AN fittings ...
Vibrant Vacuum Fittings - Aluminum
T6061 Aluminum Vibrant makes it easier to make custom air intake kits with our universal Vacuum Line Fittings Select the fitting that most closely matches the Inside Diameter of the vacuum hose line ...
Vibrant Vacuum Fittings - One-Touch Pneumatic
Unique OneTouch Design allows for simple but ultra secure tubing connections Eliminates the need for hose clamps or zip ties to secure lines These fittings are suitable for air and boost only Capable ...
Vibrant Vacuum Scavenger
Yet Another Innovative Product from Vibrant Performance Designed to allow you to scavenge excess vacuum from your motor without modifying your valve cover Very Easy to Install It is designed to thre ...
Vibrant Vanjen Clamp
Vibrant Vanjen Clamp ...
Vibrant Velocity Stacks
Vibrant Bellmouth Velocity StacksFeatures Aluminum 25 5 Inlet Diameter 6 7 8 or 875 Bellmouth Diameter ...
Vibrant Weld Bungs
Vibrant Weld Bungs ...
Vibrant Windshield Washer Bottle Replacement
The factory windshield washer bottle installed on most vehicles is a major inconvenience for anyone who has ever installed a turbocharger or supercharger on their car or simply needed to free up space ...
Vibrant Worm Gear Clamps
Designed to fit 15 to 35 Outside Diameter tubing please choose correct part for specific applications Not recommended for high pressure high temperature applications Sold in 10 Packs Only ...
Old Sep 13, 2010 | 08:59 AM
Default Re: Vibrant Performance Products
Bump it up for a Monday, thanks Honda-Tech!
Old Sep 14, 2010 | 10:34 AM
Thanks for your inquiries everyone!
Old Sep 14, 2010 | 03:33 PM
We received a big shipment today of part numbers, thanks for your interest!
Old Sep 15, 2010 | 04:09 PM
Bump it up for a Wednesday
Old Sep 16, 2010 | 03:16 PM
bump it up guys!
Old Sep 17, 2010 | 05:59 PM
bump it up for the weekend!
Old Sep 18, 2010 | 09:50 PM
Bump it up for a Saturday night!
Old Sep 21, 2010 | 10:46 AM
Thanks for all of your PMs guys!
Old Sep 23, 2010 | 11:31 AM
ttt
Old Sep 27, 2010 | 11:03 AM
bump
Old Sep 29, 2010 | 01:00 PM
ttt
Old Sep 30, 2010 | 10:48 AM
bump
Old Oct 3, 2010 | 08:45 PM
ttt
Torontopaul
Feb 14, 2018 08:07 PM
RedlineMotive
Performance
16
Nov 15, 2009 05:41 PM
oem_certified_accord
Sep 28, 2007 11:37 AM
satitus
17
Jul 11, 2007 05:07 AM
Charlie Moua
Nov 22, 2002 01:13 PM
