Performance General Performance oriented Parts (Ex: Camshafts, Electronics, Air Intakes, Exhausts, complete engines)
Supertech SS Valves
Old Oct 21, 2003 | 03:44 PM
earl's Avatar
Default Supertech SS Valves
Available for all B Series, D Series, H Series, F20, K Series, ZC
IM me for pricing
SAME PRICE FOR .5 MM OVERSIZED VALVES
Choice of flat or dished head configuration
Old Oct 21, 2003 | 04:29 PM
RenoRacing's Avatar
Default Re: Supertech SS Valves (earl)
Hey earl. are these a drop in replacement for a b16 head? or do i need to change guides? (heard that's a bitch and expensive) I've heard some valves need bigger keepers, do these?
{b16 head w/ ef1 springs, retainers, and stock keepers)
thanks for some more assistance earl!
Old Oct 21, 2003 | 04:47 PM
earl's Avatar
Default Re: Supertech SS Valves (RenoRacing)
Stock keepers and guides are used with these valves.
Old Oct 21, 2003 | 04:51 PM
RenoRacing's Avatar
right on, thats what i needed to know. I will give you a call w/ a credit card number again for one set for sure, most likely two if my friend hasn't picked some up yet. Talk to ya soon earl. thanks for the quick response and another bump for a great guy!
Old Oct 21, 2003 | 05:10 PM
KillerBee18's Avatar
do you have any dual srings and ti-retainers that you can sell along with these valves?
Old Oct 21, 2003 | 09:16 PM
earl's Avatar
Default Re: Supertech SS Valves (KillerBee18)
Yes, IM me for a package deal
Old Oct 22, 2003 | 12:08 AM
flip1199's Avatar
what's the advantage of these valves over stock besides strenght?
Old Oct 22, 2003 | 12:30 AM
earl's Avatar
Default Re: Supertech SS Valves (flip1199)
Well strength is a pretty good reason in itself
They also resist the higher temperatures generated by boosting and are lighter than stock for quicker and higher rpms.
They also come with a 30 degree back cut for better natural flow.
Old Oct 24, 2003 | 02:15 PM
rastropovitch
Guest
Posts: n/a
ttt
Old Oct 27, 2003 | 07:45 PM
Ryan C's Avatar
Default Re: Supertech SS Valves (MSchu)
bump
Old Oct 30, 2003 | 06:44 AM
kwik92hb's Avatar
hello earl what is the advantages of dished or flat,in the market for some valves just doing my research,are these the same ones u guys use
Old Oct 30, 2003 | 06:55 AM
earl's Avatar
Default Re: Supertech SS Valves (kwik92hb)
We use them in our race motors. The dished are lighter and the flat give you more compression ratio for all motor applications. I also use the Supertech valve springs and retainers and have decided to start selling them now, also.
Old Oct 30, 2003 | 07:10 AM
irev210's Avatar
do supeptech valves mushroom?
What makes them better over stock ITR honda valves?
Old Oct 30, 2003 | 03:12 PM
earl's Avatar
Default Re: Supertech SS Valves (irev210)
They are stainless steel. Any valve can mushroom on you if your geometry is off on the cams or rockers.
Old Oct 31, 2003 | 05:31 AM
b18bturbo's Avatar
same valves i used with great success guys..
Old Oct 31, 2003 | 06:29 AM
badCRX's Avatar
New User
Default Re: Supertech SS Valves (b18bturbo)
I was thinking Supertech was offering some with hardened stems, or maybe that was someone else? Can you confirm that?
Old Oct 31, 2003 | 07:26 AM
earl's Avatar
Default Re: Supertech SS Valves (badCRX)
I believe all the tips of the stems are hardened at the factory but I know about no hardened stem options. Not sure how necessary that would be.
Old Oct 31, 2003 | 07:52 AM
rastropovitch
Guest
Posts: n/a
The only thing I know would work would be to nitride the valve, but that only helps the surface hardness, Also a cryogenic process, but that is over the top for most applications.
Schu
Old Nov 9, 2003 | 11:13 AM
earl's Avatar
Correct, nitride smooths and makes the surface harder.
Old Jan 17, 2004 | 12:14 PM
b16dragger's Avatar
would i be fine running itr pistons ctr cams with your package on my b18c1 if so im me a qoute for a package i really need em asap I have everything apart right now
Old Jan 18, 2004 | 01:44 PM
smokey2.0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote"> the flat give you more compression ratio for all motor applications. </TD></TR></TABLE>
how much more compression?
Old Dec 11, 2008 | 11:51 AM
ninesecrx's Avatar
UP, If anyone needs help on these...Feel free to IM me.
vroomvroomjdm24
Dec 26, 2014 02:00 PM
tegman23
Northeast (Sales)
Nov 15, 2010 01:55 PM
b20steveo
May 28, 2009 01:28 PM
"ANONYMOUS"
Jun 19, 2008 05:02 PM
da4sale
Oct 10, 2007 12:57 AM
