Performance General Performance oriented Parts (Ex: Camshafts, Electronics, Air Intakes, Exhausts, complete engines)
A silver coilover shining under the sun
Old Mar 18, 2022 | 02:44 AM
MaXpeedingRods's Avatar
Default A silver coilover shining under the sun
A silver coilover shining under the sun, it looks so attractive!
Spring rate Front: 8 kg/mm (448 lbs/in)
Spring rate Rear: 5 kg/mm (280 lbs/in)
  • The springs were flattened on the bottom and cut straight, they are a smaller diameter than the Ts rear springs I have. But I expect a different ride anyways.
  • The rear spring and mount look beautiful and are a very good fit.
  • These have the same cup adjustment my Ts and B*s had, to be able to drop without preload.
  • These do have painted threads which is a must.
  • Shocks have a dust boot, although smaller than you may have seen before.
88LXi68
Suspension & Brakes
18
Aug 8, 2018 11:13 AM
Golddddddd
Suspension & Brakes
15
Nov 14, 2012 10:27 AM
vinuneuro
Suspension & Brakes
Oct 17, 2007 11:25 AM
KillaB-
Suspension & Brakes
Jan 28, 2005 09:12 PM
VTEConly
35
Jul 22, 2003 08:49 AM
