Performance General Performance oriented Parts (Ex: Camshafts, Electronics, Air Intakes, Exhausts, complete engines)
MAPerformance Inventory Clearance! Get it while its HOT.
Old Nov 14, 2011 | 12:53 PM
MAperformance's Avatar
Default MAPerformance Inventory Clearance! Get it while its HOT.
Hey Ya'll
Going through my inventory and clearing out some parts I have had here for awhile. Prices are way to low for me to list publicly so please just throw me a PM on what ones you would like.
PLEASE COPY/PASTE THE PART YOU WANT IN YOUR PM
ARP
-ARP 100-7711
ARP Wheel Stud Kit / Honda '80-'00 M12 X 2.85" (4 Bolt)
-ARP 100-7712
ARP Wheel Stud Kit / Honda '80-'00 M12 X 2.85" (5 Bolt)
-ARP 208-2802
ARP Flywheel Bolt Kit / Honda B-Series 1.6, 1.7, 1.8 & 2.0L DOHC
-ARP 208-4301
ARP Head Stud Kit / Honda D16A & D16Z M10
-ARP 208-4302
ARP Head Stud Kit / Honda/Acura B18A1 12pt
-ARP 208-4303
ARP Head Studs / Acura 94-01 B18C1
-ARP 208-4303*OB*
ARP Head Studs / Acura 94-01 B18C1(OPEN BOX)
-ARP 208-4304
ARP Head Stud Kit / Honda H22 A4 VTEC
-ARP 208-4306
ARP Head Studs Kit / Honda B20B, with B16A head
-ARP 208-4702
Head Stud/Bolt Kits Head Stud Kit [Honda S2000(2000-2003)]
-ARP 208-5402
ARP Main Stud Kit / Honda B16A & VTEC
-ARP 208-5404
ARP Main Stud Kit / Acura B18A1/B1
-ARP 208-6001
ARP Connecting Rod Bolt Kit / Honda/Acura 1.2L & 1.6L M8
-ARP 208-6003
ARP Connecting Rod Bolt Kit / Honda/Acura K20A
Competition Clutch
-CC 2-694-ST
Competition Clutch B Series Light Weight Flywheel (12.32lbs)
-CC 8023-1620
Stage 4 - Strip Series 1620 Clutch Kit [Honda S2000(2000-2006)]
-CC 8026-1620
Competition Clutch Stage 4 Clutch Kit / Honda B Series Hydro
-CC 8026-2100
Competition Clutch Stage 2 Clutch Kit / Honda B Series Hydro
COBB
-COBB AP-HON-001
Cobb Tuning AccessPORT / 06-09 Civic Si
Cometic
-COM C4336-030
HONDA F20C S2000 THRU '03 90MM, .030" MLS 2.0L HEAD GASKET
EIBACH
-EIB 4.1740
Eibach Sportline Kit / 92-00 Honda Civic
-EIB 4.3140
Eibach Sportline Kit / 06-07 Honda Civic 4 Cyl Inc Hybrid
-EIB 4018.140
Eibach Pro-Kit Lowering Springs / 96-00 Honda Civic (2dr/4dr) / 99-00 Civic Si
-EIB 4031.140
Eibach Pro-Kit Lowering Springs / 06-07 Honda Civic 4 Cyl Inc Hybrid
-EIB 4041.140
Eibach Pro-Kit Lowering Springs / 98-02 Honda Accord 6 Cyl
-EIB 4045.140
Eibach Pro-Kit Lowering Springs / 03-07 Honda Accord 4 Cyl
-EIB 5.81280K
Eibach Pro-Alignment Front Kit for 02-05 Civic / 02-06 Civic CR-V / 02-04 RSX
Fidanza
-FID 191471
Fidanza Aluminum Flywheel / 8lbs / 02-08 Honda Civic Si & 02-06 Acura RSX (incl Type-S)
Gates
-GAT K040400RB
Gates Micro-V Belt Honda Prelude (1992-96 / 4-Cyl. 2.3 L )
Invidia
-INV HS88HC3GTP
Invidia Catback Exhaust for EF9 Civic 3DR
King
-KIN CR4374HP
King Rod Bearings / Honda D Series
Manley
-MAN 603000-4
Manley Pistons Honda Del Sol 93-97/Civic SI 99-00 - B16A1-A2-A3 DOHC V-Tec .827"/21mm x 2.250"
-MAN 610100-4
Acura RSX 02-Up - K20A-A2-A3 DOHC V-Tec 11.5:1 CR 86mm Bore
-MAN 611100-4
Honda CRV 02-Up - K24A w/ K20A-A2-A3 Head DOHC V-Tec 87mm bore 11.5:1 CR
-MAN 611200-4
Honda CRV 02-Up - K24A w/ K20A-A2-A3 Head DOHC V-Tec 87mm 12.5:1 CR
PLX
-PLX DM-5AFR-W
PLX Devices DM-5 Wideband AFR Gauge (White)
-PLX DM-5OILTEMP-B
PLX Devices DM-5 Oil Temp Gauge (Black)
-PLX DM-5OILTEMP-W
PLX Devices DM-5 Oil Temp Gauge (White)
-PLX DM-5WATER-B
PLX Devices DM-5 Water Temp Gauge (Black)
-PLX DM-5WATER-W
PLX Devices DM-5 Water Temp Gauge (White)
Precision Turbo
-PTE 505-5857
Precision 5857SP T3 Journal Bearing Turbo w/Billet Compressor Wheel, .63 A/R V-Band
Power Slot
-POW 522PSR/L
Powerslot Rotors / Fronts / 90-08 Civic Si (Sold as Pair)
Progress
-PROG 53.1011
Progress Alignment Kit; Pivot Mounts (C)/Rear Shims (G) [Honda Accord(1990-1997), Acura Cl(1997)]
Supertech
-SUP GDE-HD55-E
Supertech Valve Guide Exhaust Honda D/K series 5.5mm stem Manganese Bronze
-SUP GDE-HD55-I
Supertech Valve Guide Intake Honda D/K series 5.5mm stem Manganese Bronze
-SUP SPRK-H1022D
Supertech HONDA S2000 / F20 and HONDA RSX-S / K20A2 Dual Valve Spring 80@ 40.4mm SPR-H1022D+RET-...
-SUP VS-H5.5E
Supertech 5.5 mm Exhaust Valve stem seal- Honda. Viton
-SUP VS-H5.5I
Supertech 5.5mm Intake Valve stem seal / Honda / Polyacrylic
Tial Sport
-TIA MVS-BK
TiAL 38mm MV-S Wastegate Black (Includes All Springs)
-TIA MVS-S
TiAL 38mm MV-S Wastegate Silver (Includes All Springs)
Varex
-XFO VMK11-350
VAREX MUFFLER OVAL BARREL 6"X 10" (15" LONG) 3.5"INLET, 3.5" Single Wall Outlet
-XFO VMK16-300
VAREX MUFFLER CANNON 7"BARREL(16" LONG) 3" INLET , 3" SINGLE WALL OUTLET
-XFO VMK17-350
VAREX MUFFLER CANNON 7"BARREL(16" LONG) 3.5" INLET , 3.5" SINGLE WALL OUTLET
-XFO VMK2G-300
VAREX MUFFLER CANNON 7" BARREL(16" LONG) 3" INLET,4.5" SINGLE WALL TIP
-XFO VMK5-300
VAREX OVAL MUFFLER 6"X10" 16" LONG BARREL Twin 3" DOUBLE WALL TIP(3" INLET)
Daelen Snow
Daelen@MAPerformance.com
763.545.3800x109
Old Nov 15, 2011 | 02:29 PM
Default Re: MAPerformance Inventory Clearance! Get it while its HOT.
I am selling this stuff at almost cost just to get it gone PM me and we can work something out!
West Werks
Dec 22, 2010 03:18 PM
gezzuzz
Jan 8, 2007 07:43 PM
rambler
Aug 13, 2002 03:01 PM
