Performance General Performance oriented Parts (Ex: Camshafts, Electronics, Air Intakes, Exhausts, complete engines)
K20 Performance
Old May 26, 2012 | 07:21 AM
AFH-Parts's Avatar
Default AFH OEM Honda Performance K Series Parts
Post kseries parts you are looking for Performance/or oem and let me get you a price shipped !!!!
*RRC Manifold $439.00 shipped
We have supplied over 400 RRC's to the K community, We work hard so you can push the limits.
And of course we also have tb adapters or any gaskets you might need with this instock all at the cheapest prices.
These are instock and ships right after payment
Paypal is hondaparts@autofair.com
**please put your screen name and order in the comment box when paying thank you.
*RBC Manifold $199.00 shipped
We have the proven RBC K-series intake manifolds
Few can afford to sell at this price.
paypal is hondaparts@autofair.com
** please put your screenname and parts info in the paypal comment box when ordering **
*RRC Crank Pulley $129 shipped
I have 2 RRC crank pulley's in stock ready to go !!. These were pretty hard to get my hands on. Brand new and fresh!!
These are literally the smallest and lightest oem K-series crank pulley available.
4.4 lbs 5 7/16" diameter
ZDX big bore throttle body $199.99 shipped
only $210 shipped modded for 8thgen!!
This throttle body setup generally for the 8thgen Civic Si owners. This is not recommended for a stock engine setup.
The emissions fitting can be run two ways. The brass NPT fitting as seen on the J35 tb setup or the cleaner look with the plugged with a vaccum T fitting for the vacumn source from the booster port. Please speicfy which you prefer when ordering. Requires the adapter. This can be installed on the RBC as well , but the tb opening on the manifold will need opened up.
-Inlet ID 78mm
-Outlet ID 70mm
please add your order and screen name in the comment box
compared to a j35 v6 throttle body
This is very similar and comparable to the TL-SH tb, but easier on the wallet. this requires the P2R adapter setup also. All instock.
*RDX Injectors Always $199 shipped in the U.S.
The ever so popular RDX injector sets with clips Brand New
Always instock!!
*Rsx-s oil pump conversion $249 shipped
This is for everyone doing a RSX-S oil pump conversion on your K-series engine, We have what you need here to get the job done
-K20A2 oil pump
-K20A2 baffle plate
-K20A2 oil pump chain
-K20A2 oil pump chain guide
-bolts for the pump and baffle
-Hondabond
We always stock everything for the swap.
*K-series 4.7 Final Drive set $279 shipped!!
Wanting to switch to the 4.7 FD?? great upgrade for the 02-04 RSX trans.
This requires bearing 91003-PPP-004 if not installed in a 05-06 RSX manual transmission, always instock $32 in addition
Brand new OEM Honda parts
*DC5 Type R Flywheel $389 shipped!!!!!
I have a new DC5 Type R flywheel here. Lightweight plus OEM quality & reliability. Weight 11lbs, ready to ship.
*5.07 CTR Final Drive $449 shipped
Were know have in stock the 5.07 Fd FOR A JDM CIVIC TYPE-R
PRB water pumps
PRB timing chain tensioners
K20Z3 upper timing chain guide
Honda K-series head gaskets
K24A2 $54.99
K20A2 $58.99
K20A3 $59.99
K24A1
K20Z3
K-Series exhaust manifold gaskets
[B]Minty fresh Brand new 02-04 RSX-S engine harness.
Looking for a engine harness for your Kswap? Tired of seeing broken plugs and crusty harness? Not looking to spend $1000 bucks on a custom harness? This is what you need!
only $275 shipped!!!
Looking for something different than the RSX setup?
The Accord shifter box and cables can be had very cheap brand new
only $174.99 shipped!! for both in the cont.48
**please add your screen name and order in the comment box
This is perfect for a custom application or with the Accord,TSX,or Z3 trans.
The Accord box has been very hard to get ahold of and we have these instock!!
- This goes perfect with the K-TUNED Z3 shifter plate kit in EG/DC/EK
Any pins/clips/washers etc... always instock as well. Add a shift **** in for a killer deal , pm me for details
*EG-DC-EK A/C delete
This is a perfect package for 92-2000 Civic's and 94-01 Integra's with a Kswap and wanting to delete the Airconditioning system while still retaining your heater. This goes where the A/C unit was under the dash and lets the air travel to the fan still . Also includes the firewall plug , All oem honda parts.
$59.99 shipped to your door
** please put your screen name and parts list in the comment box when ordering, thanks
Old May 26, 2012 | 07:23 AM
AFH-Parts's Avatar
Default Re: K20 Performance
Parts will be added everyday, if you dont see something just ask let me get you a quote with the best price and availability no problem at all
Old May 26, 2012 | 08:26 PM
AFH-Parts's Avatar
We have all your k series needs we are a dealer of mtec,remflex gaskets, Karcepts,p2r,vibrant,Brockway, and many other dealers !!!!!! Try to find another Honda dealer that does that other parts from.... Itg,stack,trs,Revotec
Pics to follow as soon as product arrives!!!!! STAY TUNED
Old May 28, 2012 | 09:10 AM
AFH-Parts's Avatar
All Kseries Parts on sale today !!!!
Old May 28, 2012 | 04:02 PM
AFH-Parts's Avatar
OPEN 7AM TO 9PM MONDAY THRU FRIDAY AND 7AM TO 6PM SATURDAYS !!!!!
Old May 29, 2012 | 09:47 AM
AFH-Parts's Avatar
LOTS OF PARTS ADDED !!!!
Old May 29, 2012 | 09:55 AM
AFH-Parts's Avatar
karcepts added !!!!!
Old May 29, 2012 | 10:34 AM
AFH-Parts's Avatar
ACCORD SHIFTER BOX AND CABLES ADDED
Old May 29, 2012 | 01:15 PM
AFH-Parts's Avatar
HERE TILL 9PM
Old May 30, 2012 | 11:49 PM
RagingAngel's Avatar
You have PM.
Old May 31, 2012 | 12:13 AM
doood's Avatar
been there done that
bump for a great company. i've bought from you before and will buy all my oem parts from you.
Old May 31, 2012 | 08:37 AM
AFH-Parts's Avatar
Thank you
AFH-Parts's Avatar
Originally Posted by RagingAngel
You have PM.
Old Jun 1, 2012 | 04:55 AM
AFH-Parts's Avatar
PACKAGE DEALS AVAILABLE !!!!!!
Old Jun 2, 2012 | 03:51 AM
AFH-Parts's Avatar
EG-DC-EK A/C delete KITS ADDED
Old Jun 2, 2012 | 04:03 AM
AFH-Parts's Avatar
MTEC SPRINGS ADDED
Old Jun 4, 2012 | 08:58 AM
AFH-Parts's Avatar
ttt
Old Jun 6, 2012 | 03:22 AM
AFH-Parts's Avatar
ttt
Old Jun 7, 2012 | 10:36 AM
AFH-Parts's Avatar
TTT
Old Jun 8, 2012 | 07:12 AM
AFH-Parts's Avatar
ANOTHER ORDER OF ZDX DBW THROTTLE BODYS IN GET THEM NOW !!!!!!
Old Jun 11, 2012 | 08:25 AM
AFH-Parts's Avatar
J35/TL TYPE S/ZDX THROTTLE BODYS IN STOCK
Old Jun 12, 2012 | 11:39 AM
AFH-Parts's Avatar
RRC AND RBC MANIFOLDS TONS IN STOCK !!!!! BEST DEAL ON THE PLANET
Old Jun 14, 2012 | 11:08 AM
AFH-Parts's Avatar
TTT
Old Jun 15, 2012 | 03:02 AM
AFH-Parts's Avatar
ttt
Old Jun 16, 2012 | 03:36 AM
AFH-Parts's Avatar
TTT
