Performance General Performance oriented Parts (Ex: Camshafts, Electronics, Air Intakes, Exhausts, complete engines)
GOLDEN EAGLE #1 Source for Performance Engine Blocks and Products
Old Oct 22, 2010 | 07:57 AM
Golden Eagle's Avatar
Default GOLDEN EAGLE #1 Source for Performance Engine Blocks and Products
If Your Search For a Dependable Engine Block Has
Lead You To a Dead End
G.E.. IS HERE TO HELP YOU.
Performance and value made in the USA.
Generating extra cubes via G.E. big bore sleeves is a good
solid technique to gain more lbs.ft. even if nothing else is
done to the
engine.
G.E. STROKER STRATEGIES FOR HIGHER HORSEPOWER
Add a stroker kit to the mix and get an even better increase
of power.
For over a decade
G.E. has focused on supplying the
professional engine builder and back yard mechanic with
the best performance products in the business at a price
that is affordable. G.E. is focused on being on the
cutting edge
of engine and part development.
The next time you build your engine use G.E. sleeves and products.
www.goldeneaglemfg.com
Old Oct 26, 2010 | 08:42 AM
MadHead's Avatar
Default Re: GOLDEN EAGLE #1 Source for Performance Engine Blocks and Products
pm'd you!
Golden Eagle
Oct 23, 2010 01:00 AM
Golden Eagle
Oct 22, 2010 08:02 AM
Golden Eagle
Performance
Oct 19, 2010 08:17 AM
