Performance General Performance oriented Parts (Ex: Camshafts, Electronics, Air Intakes, Exhausts, complete engines)
ENGINE MOUNT BRACKETS, HYDRO CONVERSIONS, A/C BRACKETS AND MORE FOR YOUR SWAP
Old Mar 27, 2010 | 02:13 PM
HAMOTORSPORTS's Avatar
Default ENGINE MOUNT BRACKETS, HYDRO CONVERSIONS, A/C BRACKETS AND MORE FOR YOUR SWAP
Need something to finish your engine swap? We have everything you need at HA Motorsports! We specialize in Honda / Acura engine swaps, so we know it can get tough finding the miscellaneous parts you need to finish your swap. To help you get on your way, we stock engine mount brackets, cable to hydro conversion kits, alternator relocation brackets, A/C brackets, and so much more. For a complete list of what we have to offer, visit us at http://www.hamotorsports.com/brackets.html
HA Motorsports
Shop online 24/7 , or call us to order 209-324-9880
For a shipping quote, simply add the item to your shopping cart and enter your zip code on our shipping calulator
B Series 2 Bolt Post Driver's Side Engine Mount
This 2 bolt style bracket bolts to the timing belt side of your B series engine block. This bracket comes factory on 92-00 B16 engines. You will need this bracket to bolt any 88-91 B16, 92-93 B17, or 90-01 Integra B18 engine into a 92-95 civic chassis when using a 2 bolt style mount kit, or on any 96-00 Civic using a Hasport EKSTK mount kit.
B series rear engine L bracket for 92-95 civic EG and 94-01 Integra with B series engine.
This is the required rear bracket for any B series engine swap into EG/ DC2 chassis.
Many other engine brackets are in stock and ready to ship as well. To find what you need visit us at http://www.hamotorsports.com/brackets.html
Innovative Hydro to Cable conversion bracket for 96-00 Civic EK
This conversion kit will allow you to install a B series cable transmission into any 96-00 civic using stock or aftermarket mounts that were originally designed for a hydraulic B series transmission.
Innovative 88-91 Civic , CRX A/C Compressor Bracket
This AC conversion bracket will allow you to bolt up your stock D series A/C compressor to a B series engine. Enjoy your B series engine and keep the luxury of AC
92-95 Civic B series A/C Bracket
This AC bracket will allow you to bolt up your factory 92-95 civic D series A/C compressor to any B series engine. Simple bolt on installation. This is a much better option than trying to use a B series compressor and having custom AC hoses made.
Innovative 96-00 Civic EK H22 Swap A/C Bracket
This bracket allows a simple bolt on installation of your stock D series A/C components onto an H series engine. Keep your Big Block H22 and your A/C
Innovative H22 Alternator Relocator Bracket
This alternator relocation bracket is designed for all F and H series engines. Relocates the alternator to where the H22 A/C compressor was for more clearance. Also available in a 1/2" offset for use on applications not using a balance shaft belt
Hasport D series Cable to Hydraulic Conversion Kit
This Hasport Cable to Hydro D series conversion kit allows your factory 88-91 Civic or CRX clutch cable to operate a D series hydraulic transmission clutch lever.
Hasport B Series Cable to Hydraulic Conversion Kit
This Hasport Hydro conversion kit allows you to operate a hydraulic B series transmission in an originally cable transmission car like the 88-91 Civic / CRX , 84-87 CRX, 86-89 Integra, or 90-93 Integra when using either an Innovative or Hasport Hydraulic mount kit.
Innovative Cable to Hydraulic Actuator
This is the most advanced cable to hydraulic clutch conversion kit on the market. It offers a true hydraulic conversion from a cable chassis using an actual hydraulic master cylinder with Innovative's high-quality actuator assembly.
For a complete list of everything we have to offer, please stop by our website here http://www.hamotorsports.com/brackets.html
THIS THREAD IS BEING CLOSED TO ALLOW ROOM TO ADVERTISE MORE OF THE GREAT PRODUCTS WE HAVE TO OFFER. BUT THE ITEMS ARE ALWAYS KEPT READY TO GO AND THE GREAT PRICING CONTINUES....PLEASE DON'T HESITATE TO CALL US 209-324-9880 WITH ANY QUESTIONS OR VISIT US ONLINE 24/7
HA Motorsports
209-324-9880
Old Mar 28, 2010 | 12:32 PM
GsReKBabE's Avatar
TRIAL USER
Default Re: ENGINE MOUNT BRACKETS, HYDRO CONVERSIONS, A/C BRACKETS AND MORE FOR YOUR SWAP
bump...
Old Mar 28, 2010 | 04:24 PM
Originally Posted by GsReKBabE
bump...
Thanks!!
Here's another one of our popular items:
Hasport EFAC / EFBAC 88-91 Civic or CRX EF B Series A/C Compressor Bracket
This machined billet AC bracket allows you to run A/C and your B series engine! This Hasport Air Conditioning bracket kit comes with everything you need to bolt your stock EF D series Matsushita or Sanden compressor to a B series engine. Requires re-use of the D series SOHC AC tensioner pully.
Have questions? Give us a call 209-324-9880
Old Mar 29, 2010 | 07:26 AM
Yes, we have shift linkages too!
Innovative Mounts Shift Linkage for 88-91 Civic / CRX EF with B Series
This Innovative shift linkage is designed for perfect fitment into any 88, 89, 90, or 91 EF civic or crx manual transmission chassis when using an Innovative B series mount kit. Don't bother trying to cut your stock linkage and welding on the B series end. This linkage is priced very competitively so everyone has the oportunity of having a crisp shift linkage and accurate shifts.
Old Mar 29, 2010 | 11:01 AM
HA-EG6's Avatar
ttt
Old Mar 29, 2010 | 03:46 PM
HA-EG6's Avatar
bump
Old Mar 29, 2010 | 09:38 PM
Need to convert your 96-00 Civic EK from hydro tranny to cable? This Hasport 96-00 Civic EK Hydraulic to Cable Conversion Bracket allows you to install a cable transmission into your EK with any set of standard 96-00 Civic motor mounts. This bracket simply bolts to the chassis to allow your stock or aftermarket motor mounts to fit with your cably tranny.
Old Mar 30, 2010 | 10:20 AM
HA-EG6's Avatar
uh bump bump bump
Old Mar 30, 2010 | 11:53 AM
HA-EG6's Avatar
Old Mar 30, 2010 | 02:56 PM
HA-EG6's Avatar
ttt
Old Mar 31, 2010 | 06:33 AM
engine mount bracket galore!
Old Mar 31, 2010 | 11:24 AM
TTT
Old Apr 1, 2010 | 12:50 PM
ttt
Old Apr 1, 2010 | 05:25 PM
If you need to install a hydraulic (hydro) transmission into your 90-93 DA integra, look no further than the Hasport EFBHCL Cable to Hydro Conversion Kit This Hasport kit will allow your cable chassis to operate your hydro b series transmission with ease!
Old Apr 2, 2010 | 07:31 AM
ttt
Old Apr 2, 2010 | 12:32 PM
ttt
Old Apr 2, 2010 | 04:23 PM
HA-EG6's Avatar
ttt
Old Apr 2, 2010 | 07:58 PM
ttt
Old Apr 3, 2010 | 01:15 PM
ttt
Old Apr 4, 2010 | 09:03 PM
ttt
Old Apr 5, 2010 | 08:15 AM
ttt
Old Apr 5, 2010 | 11:40 AM
HA-EG6's Avatar
ttt
Old Apr 5, 2010 | 02:17 PM
HA-EG6's Avatar
ttt
Old Apr 5, 2010 | 08:41 PM
We have another huge order of these Motor mount brackets on the way. All current backorders shipping out first thing Wednesday morning!
209-324-9880
Old Apr 6, 2010 | 08:07 PM
ttt
