what stuff to use on bumper?
Old Sep 28, 2008 | 08:50 PM
lilo_goki's Avatar
Default what stuff to use on bumper?
shoud i use the bondo on my civic front bumper, would it be good. i'm just using it to fill up the scratches that i have on my bumper and to fill up the holes that holds the license plate.
Old Sep 29, 2008 | 12:21 AM
mfef4dr's Avatar
Default Re: what stuff to use on bumper? (lilo_goki)
use SEM flex putty, I think the product number is 39482
EDIT: heres the info/tech data sheet
http://semproducts.com/Catalog.asp?prod=122
Old Sep 29, 2008 | 03:48 AM
powerflow's Avatar
Default Re: what stuff to use on bumper? (mfef4dr)
If your filling holes, you really need to do it right to make it look good after paint and lessen the chance of it cracking easily or sinking in. Your not going to get away with just using a glaze filler. You should use some type of epoxy repair kit for flexible bumpers around the back side. Then very thin flexible glaze coat on the front side of the bumper.
Old Sep 29, 2008 | 04:44 AM
Cuda's Avatar
i speak from experience... but theres this thing called "Rage Gold".. and i HIGHLY recommened using that..
its lighter, easier to sand, and just overall BETTER than bondo will ever be..
Old Sep 29, 2008 | 10:51 AM
mfef4dr's Avatar
Default Re: what stuff to use on bumper? (powerflow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by powerflow &raquo;</TD></TR><TR><TD CLASS="quote">If your filling holes, you really need to do it right to make it look good after paint and lessen the chance of it cracking easily or sinking in. Your not going to get away with just using a glaze filler. You should use some type of epoxy repair kit for flexible bumpers around the back side. Then very thin flexible glaze coat on the front side of the bumper. </TD></TR></TABLE>
Yeah. the flex puddy is only good for small things like scratches, rock chips, ect.
Old Sep 29, 2008 | 02:43 PM
powerflow's Avatar
I wouldn't use Rage Gold either in this case, misapplication imo. I would use Poly-Flex for a skim filler on a flexible bumper, also a good 2K primer w/ flex additive if available.
For overhauling a bumper I prefer to buzz it down really good, fill anything too deep for high build primer to fill, which at that point shouldn't be much, then finish prep, prime. The less filler the better.
Mossy
Paint and Body
Apr 20, 2017 11:14 AM
H.I CTR
Paint and Body
Dec 11, 2008 10:51 PM
akces
Paint and Body
Mar 28, 2008 06:39 AM
mamaboy
Jun 16, 2005 09:03 AM
B18ls*RAYON
Jan 17, 2005 12:04 AM
