stripping wheels
Old May 21, 2007 | 03:36 PM
91ed9's Avatar
Default stripping wheels
i got civic Si wheeels and ineed to stripp the finish completely off
will aircrafts stripper be good
there 99 civic Si wheeels
or let me knwo if there is anythign eslse i could use
thanks
-John
Old May 21, 2007 | 03:47 PM
harmonator84's Avatar
Default Re: stripping wheels (91ed9)
yea you could use aircraft stripper. What is it the clear coming off?
Old May 21, 2007 | 07:40 PM
91ed9's Avatar
Default Re: stripping wheels (harmonator84)
idk everythign is coming off bc i sanded it a little to see if it was the clean and nop lol
ill get pictures up
actually if you look on my build page i believe i ahve a pic of one of the wheeels up there
idk what page its int he beginning some where
Old May 23, 2007 | 06:50 AM
91ed9's Avatar
for some reason the aircraft stripper didnt take it off
i kept it on there for a while and then scrapped it off and nothing
hmm....
i need to get this off today bc i go in for surgery tomoorrow and i want them done
Old May 23, 2007 | 10:21 AM
ST4TUS's Avatar
Try again.
This is the only safe way to do it... I wouldnt try anything else in fear of damaging the wheel.
Aircraft remover should do the job, try it a few times and make sure you use a generous amount...I wouldn't rush it because if you use anything too coarse on the paint, you could corrode the actual wheel and thats no good.
You also may want to scuff them after you take as much of the finish off that you can. Although you cannot tell all the time (especially with the silver on the wheels) you take more off than you'd think
Aircraft Remover
400-600 grit
Old May 23, 2007 | 11:05 AM
goalieman24's Avatar
I used a few different coats of Aircraft stripper... often using a pressure washer in between coats.
Old May 23, 2007 | 02:28 PM
91ed9's Avatar
Default Re: (goalieman24)
alright yeah i only put on one coat of aircraft remover but it was a generous amlunt :-p
i gotta strippe them bc they are corroded a bit and im going to paint them bronze i think
but it will have to wait till next weekend bc i have to go infor surgery tomorrow
i will let you guys knwo how it goes next week or so
thanks again~
ke7joi
Classic Hondas
Nov 11, 2011 10:35 AM
2ndgent3g
Jul 21, 2008 02:34 PM
HPCO$T
Aug 2, 2005 11:13 AM
Mike P.
Jan 17, 2002 07:20 PM
