some questions on prep
Old Mar 7, 2010 | 11:56 AM
perseverance's Avatar
Default some questions on prep
yes, i've searched and i've read and learned a lot. There are still some things i'm not certain of. They say the 50 dollar paint job sucks when u try to paint over it. well, i rattle canned my front fenders. My car was stolen and completely stripped, and i built again pretty much from the ground up. i figured i just wanted my front end to match the rest of my car and well i sprayed the fenders. it looks pretty good as i paint a lot of stuff with rattle. From what i hear i have to sand it down to bare metal, well i don't mind that. but i want to prime it after wards. Is rattle can primer bad? i'd hate to buy new fenders since these are nice and aren't bent. Also, as far as prepping the car for paint, i'm going to maaco...what grit sand paper should i take to the car? i prefer to scuff it before they scuff it because who knows if they'll actually scuff it before they paint it. it's either going to be econopaint or maaco. thanks in advance! btw, if u can recommend a particular rattle can primer that will do the trick i'll pick it up. thanks again!
Old Mar 7, 2010 | 12:28 PM
SVOHK's Avatar
Default Re: some questions on prep
You should read my thread i pretty much asked the same questions.
I wanted to use rattle can primer to primer my car but all i got was
https://honda-tech.com/forums/paint-body-84/prepping-my-car-paint-am-i-doing-right-2735596/
Old Mar 7, 2010 | 03:12 PM
hmm well, there's some good info on there. the fenders need to get sanded to metal and then primered which will be easy. i'll spray some air craft remover on it first, then finish it up with a da sander. did u wind up using the rattle can primer because that's what i wanna do.
Old Mar 10, 2010 | 10:53 PM
SVOHK's Avatar
I did end up using the rattle can primer on SOME spots.
If your just gonna primer the fenders it should be alright, but rattle can primer isnt the best recommendation.
AlterEgo
Paint and Body
Mar 3, 2010 01:28 PM
evil_ryu
Paint and Body
Oct 30, 2009 05:46 PM
CPreston
Paint and Body
13
May 1, 2009 05:25 PM
UnoPuntoCinco
Paint and Body
May 26, 2007 04:00 PM
cr-x si
Nov 10, 2002 08:05 PM
