Sidemarkers install
Old May 18, 2011 | 03:52 PM
lxdriver's Avatar
Default Sidemarkers install
I want to install sidemarkers on my ej6 but I dont want to try it out and end up with a f***ed up fender, does anyone have any instructions on how to do it properly. I already have the sidemarkers ($20 eBay very OEM look-a-likes). Thanks in advance guys/gals.
Old May 19, 2011 | 12:25 PM
ptōwn_gżżżr's Avatar
Default Re: Sidemarkers install
Masking tape , pencil , and that air tool , forgot the name...
Old May 19, 2011 | 03:39 PM
gorillafart's Avatar
steak knife, ruler, duct tape, glue. paperclips, speakerwires
Old May 20, 2011 | 01:21 PM
traderj's Avatar
What ptown said. But you can use a dremel with a reinforced cutting disk. The only thing I would add is make sure you come up with a mirrored template for the other side. Would hate to put the one side in and be off a little on the other.
Old May 21, 2011 | 12:30 PM
ekracing's Avatar
just make sure you measure properly so the other sides looks the same, i put the marker lights where i wanted it then marked around it with a sharpy. i did mine with a dremel, took about 30 mins. i used the cutting drill bit. just go slow and you be fine. i cut a little smaller and used the cutting disk to make bigger for tight fit. wire up to cornerlight and your done. hope that helps.
Old May 22, 2011 | 07:02 PM
Mikie's Avatar
https://honda-tech.com/forums/lighting-107/%2A%2Aofficial%2A%2A-oem-eg-dc-sidemarker-template-2571230/
there is the link for the template...
i installed my sidemarkers before my car was painted, i took the fenders off and printed out the template... if you want the template for the other fender just flip it on your print menu... pretty basic.
dont worry about wrecking your fender, the template is a tiny bit smaller then what the actual sidemarker is... so youll notice once you cut the holes open and put your sidemarker up to the fender it will be too tight, so youll spend a little bit of time shaving the sides to get the sidemarkers to fit. The plastic border around the lights are decently thick so it will cover your hole completely.
but make sure you wire them and test them before you clip the lights in and put the fenders back on.
Old May 22, 2011 | 09:03 PM
lxdriver's Avatar
Thanks mikie, but those templates you provided are for the EG/DC and I have an EK so I'm not sure if they'll work for me 2, will they?
Old May 23, 2011 | 05:41 PM
Mikie's Avatar
oh crap sorry man i wasn't paying attention to that, as soon as i seen sidemarker install i just assumed it was EG, i skimmed over the message.
but ya your right, thats the DC/EG sidemarker template, EK is different...
i did a little bit of research and i did find this..
https://honda-tech.com/forums/paint-body-84/diy-ek-side-maker-made-easier-2505630/
Hope this helps out man...
post pictures and let us know how it went.
Old May 24, 2011 | 09:59 PM
lxdriver's Avatar
Yeah thanks mikie, that link to another thread pretty much already has the sidemarkers installed on my car cuz its so easy, I just have to check out the templates from the external site and hope they still work. Thanks though and I'll try to put pics of the finished install
Old May 25, 2011 | 06:57 PM
96MSkuter's Avatar
Does any body have pics of the wiring I'm having trouble finding info on this and I'm trying to wire them the JDM way? Thanks
Old May 26, 2011 | 10:53 AM
lxdriver's Avatar
I dont have pics but for each style u have to tap into the wires like this:
USDM:
Tap into green(turn signal) and black(ground) wire.
JDM:
Tap into red(parking light) and green(turn signal) wire.
Check out this link on the complete DIY: (or the one above)
http://forums.clubsi.com/ubbthreads....te_id/1#import
Im just waiting on my metal nibbler from radioshack to arrive to install them on
Old May 26, 2011 | 07:40 PM
229ek9's Avatar
Thanks for the wiring link I needed that!!!
q45mm
12
Sep 11, 2010 10:37 AM
BadaMaash
Honda Civic (2001 - 2005)
Feb 10, 2009 06:31 PM
b3nj1honda
13
Apr 3, 2008 09:39 AM
Aznracerboy54
Aug 12, 2005 01:49 PM
