shaved molding removal
Old Dec 27, 2008 | 09:55 AM
ayos ctr_hatch's Avatar
Default shaved molding removal
I want to put back the mouldings on my hatch, it was filled with fiberglass. I already got traded doors, so I only have to remove the rear quarter panel and the front fender. Could I do this without damaging the body.
Old Dec 27, 2008 | 11:56 AM
bigD's Avatar
Default Re: shaved molding removal
only way to know is to try, if you still have the old doors practice on them if not then I would try the front fenders first, you can always pick up new ones pretty cheap.
Old Dec 27, 2008 | 01:25 PM
crxjarred's Avatar
couldnt u sand blast it off?? dont sand get anything off but metal
Old Dec 27, 2008 | 04:27 PM
stillrockin18s's Avatar
get your self some wire wheels that go on the end of a drill. You may need a couple of them.
Old Dec 28, 2008 | 06:38 AM
precisionsc54's Avatar
die grinder
Old Dec 29, 2008 | 08:17 AM
kp's Avatar
kp
I'd try from the end with maybe a small chisel or pointy screwdriver. Bang it in just to start it off and then work your way down. Once you have most of the fibreglass/bondo out, go to town on it with a coarse wire wheel on a grinder (or a drill). You'll probably end up repairing a lot of the marks from your tools but at least you'll end up where you want.
Old Dec 30, 2008 | 07:01 AM
Thats why you want to just use a wire wheel, it leaves a relatively undamaged surface, just bare metal.
Old Dec 30, 2008 | 10:20 AM
gorillafart's Avatar
its just fiberglass... hammer and chisel for roughing it out. sand/grind the rest
good thing yor car's moldings werent shaved professionally cuz then you would've had to replace everything
Old Dec 31, 2008 | 12:16 AM
yayizzil's Avatar
ok i have the same thing i was thinking of....how do u get that bondo **** off of the fuking side moldings want to do it to my hatch too bought it like that and dont like it now lol....anyone besides the beating on its and wire wheel imm try them though....
Old Dec 31, 2008 | 04:49 AM
Thats about your best bet. Just sucks because you have those holes from the moulding clips and the bondo likes to go in there and act as a fastener.
Old Dec 31, 2008 | 06:28 AM
Always try a torch and a pick, I would recommend it though.
I have "de-shaved" a integra and a civic before, I used the wire wheel method for both.
chad
Welding / Fabrication
Jun 22, 2010 05:24 PM
Batoutahell
Mar 15, 2004 09:07 PM
2000CX
Feb 3, 2003 02:15 PM
