seam question in bay
Old Mar 11, 2011 | 07:58 PM
markD.'s Avatar
OMG it'Z McFLY!
Default seam question in bay
I welded every seam in my bay, not stitch welded, a continuos bead in every seam. I then ground down all the welds and bought evercoat metal glaze. is it ok to use the metal glaze directly on the seam itself? I'm thinking it will be ok since I added so much rigidity welded the seams..or should I have used a sandable seam sealer and then the metal glaze? I'm afraid of cracking but not too sure. opinions?
Old Mar 11, 2011 | 11:53 PM
gorillafart's Avatar
Default Re: seam question in bay
just to let you know you may have "Added" rigidity but you also have altered the engineering of how your car is supposed to react in a collision. for show purposes, shaving your engine bay may be fine. but you may or may not have compromised your safety in a collision.
either way... i wouldnt use metal glaze right away, that stuff is too expensive and is meant for small pinholes and surface dings. for the engine bay i would use regular bondo and since you're using evercoat. i would recommend one of their rage products. then if u really wanted to, you can put metal glaze as the finishing putty. on top. you possibly could've used sandable seam sealer, but i think bondo is faster.
Old Mar 12, 2011 | 06:19 PM
shocker911's Avatar
exactly
i would use a filler instead of all metal. A.cheaper B.have you sanded all metal before? pain in the ***. filler will be fast cheaper and still do exactly what you want to do with the metal glaze
Old Mar 12, 2011 | 06:49 PM
All Metal and Metal Glaze is different just to let you know...
Old Mar 12, 2011 | 07:50 PM
shocker911's Avatar
i just noticed that...i have only used all metal and i hated every second of it.
Old Mar 13, 2011 | 11:20 AM
hahah.
i think all metal is used mainly for aluminum panels.
Old Mar 15, 2011 | 08:25 PM
markD.'s Avatar
OMG it'Z McFLY!
yeah i didnt use that haha. im just worried of cracking..but i think itll be alright because of the added rigidity. but im still curious thats why i was asking anyone that might know.
Old Mar 20, 2011 | 09:44 AM
markD.'s Avatar
OMG it'Z McFLY!
anyone else?
Old Mar 31, 2011 | 12:37 PM
markD.'s Avatar
OMG it'Z McFLY!
Old Mar 31, 2011 | 05:16 PM
what else do you need to know? do you not believe me? lol
dev203d
Welding / Fabrication
Nov 18, 2010 02:37 PM
dc4teg95
Paint and Body
10
Nov 23, 2009 12:59 PM
civic-one
Paint and Body
15
Jul 1, 2009 03:52 PM
RedneckRicer
Paint and Body
May 10, 2008 06:33 AM
4DRmafia
Paint and Body
Aug 2, 2007 05:16 PM
