sanding clear
Old Jan 10, 2012 | 04:16 AM
brad22486's Avatar
Default sanding clear
shot some clear yesterday and got some runs when can i sand them out and clear again?
Old Jan 10, 2012 | 06:36 AM
trueblood's Avatar
Default Re: sanding clear
How bad are the runs? Can you sand and buff? They make a file for knocking down 90% of the runs before you sand with 1000 grit, 1500 grit, 2000 grit and buff. I have seen people use easy sanding bondo and apply over run. sand aggressive until bondo is almost gone then switch to 1200 grit sandpaper.
I would wait 48 - 72 hours unless you used snap dry.
Thought this was a cool tip when I saw it.
http://www.custompaintforum.com/foru...un-Removal-Tip
Old Jan 10, 2012 | 01:03 PM
jasoncrashtech's Avatar
sometimes you can sand out a run without re-clearing. just keep working at it until the wave is gone, if you sand or rub through block it out and re-clear.
Old Jan 10, 2012 | 03:31 PM
brad22486's Avatar
the runs are pretty bad wasnt paying attention and my wife was rushing me so i planned on sanding out runs and re clearing
Old Jan 10, 2012 | 03:46 PM
mike703's Avatar
^^^^^ Good answer
Old Jan 10, 2012 | 05:09 PM
gorillafart's Avatar
800-1000grit and reclear
Old Jan 11, 2012 | 07:20 PM
joeshmo's Avatar
Razor blade or small file, then sand and buff. That spot putty trick works very well also.
Old Jan 12, 2012 | 08:25 AM
brad22486's Avatar
k ima clear the car and let it cure then ill take care of the runs that will give the small parts w runs 4 days of curing
raverx3m
Paint and Body
Dec 18, 2013 07:55 PM
Acidcrakker
Paint and Body
20
Dec 7, 2008 06:53 AM
joseesp
Paint and Body
Mar 6, 2008 12:37 PM
Ep1dem1c
Paint and Body
Aug 24, 2007 10:26 AM
1.8
Nov 28, 2004 11:24 AM
