rust
Old Jun 19, 2007 | 06:45 AM
hondamannn's Avatar
Default rust
I have just small amount of rust on my car. Has anybody used a rust dissolver such as this before? I would like tp spend just a few dollars to fix the problem as it is really a small area. But I will spend more if I have to.
http://www.autobodytoolmart.co....aspx
Old Jun 19, 2007 | 11:10 AM
Boost_V's Avatar
Default Re: rust (hondamannn)
can you put up some pics of the area?? i don't know how that stuff works, though.
Old Jun 20, 2007 | 11:52 PM
bobjohnson's Avatar
Default Re: rust (Boost_V)
If the rust is on the body of the car, that stuff will probably eat right through the panel, if it works how i think it works. Plus it will probably peel the paint off all around. I have a bottle of stuff like that i tried to use on my steelie rims, it worked well, ate through the rust and turned it into primer like it said, but it also ate through rust i couldnt see and peeled big chunks of the chrome off, which also made fixing it properly (Sanding, then repainting) even harder on the wheels i used it on, because the "primer" it turns the rust into is a pain to sand down.
But yeah, post pictures, if its just some light rust stains from bolts leaking or something, then this will probably work if you put some on a cloth and lightly rub it over the rust streak. I did that with my licence plates, took the rust off without eating the paint, made them look brand new.
Mistermark
Welding / Fabrication
18
Feb 17, 2006 11:37 AM
DarkBB4
Apr 26, 2005 10:52 AM
typhoon
Sep 20, 2004 09:17 AM
lke2drvgsr
Jun 18, 2004 03:54 PM
Soda Popinski
10
Mar 7, 2004 07:59 PM
