removing watermarks
Old Aug 28, 2010 | 09:20 PM
Killa Vanilla's Avatar
Default removing watermarks
Have a question: What's the best way to remove watermarks on a car? I have a 2001 integra. I was gonna try claybarring the whole car, but someone told me to use very fine steel wool and wax on the windows. Has anyone else heard this? sounds risky.
Old Aug 28, 2010 | 09:28 PM
hondawhiz's Avatar
Default Re: removing watermarks
steel wool on the windows only. but clay is bomb for the body.
Old Aug 28, 2010 | 11:27 PM
thanks, i guess ill try it.
Old Aug 29, 2010 | 07:54 AM
rxbahamut's Avatar
If the claybar does not work on the body, try some wax and grease remover, you can use 2500 grit to get them out and then compound it and polish it with a buffer. But start with the claybar, and other non abrasives first.
Old Aug 29, 2010 | 08:05 AM
filthy94's Avatar
super fine steel wool works great on windows. we use it at the body shop to get accidental overspray off them and polish rust off of chrome. i problydont need to say this but DO NOT use steel wool on the body of the car
Old Aug 29, 2010 | 11:42 AM
gorillafart's Avatar
yeah, that steel wool better be super fine.
Old Aug 30, 2010 | 03:16 PM
rxbahamut's Avatar
I am sorry I did not read the windows. I thought you were doing the whole body.
Old Aug 30, 2010 | 09:50 PM
yea that confused me a lil.
as for the steel wool, didn't work! maybe I should use a less fine grit? worked fine on mirrors though
Old Nov 16, 2010 | 10:38 PM
bringing this back from the dead.
new methods tried:
steel wool--FAIL
vinegar--FAIL
limeaway--FAIL
limeaway+steel wool--FAIL
I don't know what to do now. Any other suggestions?
Old Nov 17, 2010 | 01:08 AM
xrsallday's Avatar
polishing compound works good on windows and paint. i have a white EJ1 and the clearcoat is gona and the polish works good to remove dirt stains etc. but theres this stuff my dad bought called granitize hard waterspot remover that you have to dilute, it works wonders, just dont get any on your paint!
Old Nov 17, 2010 | 11:51 AM
jasoncrashtech's Avatar
buff the paint, if some water marks don't come out wet sand them a little bit with 2000 grit wet sand paper. you will need about three or four progressive compounds and pads for final finish.
if you need to ask this question then i would guess that you haven't done this before, in that case i think you should take it to a shop and explain to them what you want. if you want to learn this try to find someone that has real experience with paint.
i wouldn't want to give you advise that would lead you to burn the paint
Old Nov 17, 2010 | 03:19 PM
would you use polishing compound/granitize + a polishing wheel? or just straight-up hard work?
@jasoncrashtech: yea the paint is fine, it's on the windows.
Old Nov 17, 2010 | 04:19 PM
DC2.2_GSR's Avatar
on the windows? If steel wool didn't kill it then it's not water marks. As was mentioned above, I use steel wool on windows to remove fully cured paint overspray. There's no way it would just leave the water marks.
Post pics if you can, I'm curios to see what the marks actually are.
Tranceaddict87
Paint and Body
Jun 3, 2008 07:21 AM
1slowcrx
Welding / Fabrication
Jan 5, 2006 12:00 PM
trigun7469
Nov 22, 2003 07:28 PM
Audipwr1
May 8, 2003 08:27 PM
serious
Dec 13, 2002 08:47 PM
