Rattlecan Primers
Old Jul 26, 2010 | 06:28 PM
H22EG'z's Avatar
Default Rattlecan Primers
Hey guys what kind of Rattle can primer can i use to cover my body work and have it be compatible with automotive paint? I used rustoleum to fix some spots because that's all i had around at the time but will it melt through an automotive paint? or will it be ok, i have heard mixed things.
Old Jul 27, 2010 | 06:14 AM
rayfrank's Avatar
Default Re: Rattlecan Primers
I've always used anti-primers on my models, and has never had much of a complaint, except the relative expensiveness of primers hobby, probably largely due import costs of stuff. The virtue about Tamiya spray can primer is that you can spray the outside. I use an airbrush in a booth with filter and mask painting, but I would not even boot at risk.
Old Jul 28, 2010 | 04:44 PM
H22EG'z's Avatar
Um, im confused are you talking about use on a real car or model cars?
Old Jul 31, 2010 | 05:08 PM
D7_62's Avatar
Was that even english? My brain is confused.
Old Aug 4, 2010 | 03:20 PM
SVOHK's Avatar
lulz in this thread.
i was told using rattle can primer will crack over time.
i used rattlecan rustoleum filler primer for a paint job and i had no problems.
Old Aug 4, 2010 | 06:21 PM
H22EG'z's Avatar
yea i used some Rustoleum or whatever primer on my car but i was told it will eat through the paint , i started using high build primer filler in a can to do my doors, i never heard it could crack.. hmm.
Old Aug 5, 2010 | 09:27 AM
93h2beg's Avatar
go to a autobody supply shop, they have high build auto primer in cans, not cheap but if u get the right stuff it will be compatible with auto paint.
Old Aug 5, 2010 | 10:38 AM
rs250nut's Avatar
Over here in the U.K you can get 2k high build in a rattle can, sounds strange but has a plunger on the bottom of the can to activate. Works a treat and are ideal for spot repairs etc. See if you can get something similar
Old Aug 5, 2010 | 03:00 PM
SVOHK's Avatar
Originally Posted by Eighteenvolts
your doing in correctly but dont use that rustoleom. It'' slowly crack after a year or so.
This guy told me.
I used it anyways. For the doors only.
Its been like 5 months after the paint job and still looking good no cracks on the doors. Keep in mind this was a maaco paint job
Old Aug 5, 2010 | 03:01 PM
SVOHK's Avatar
Interesting.. how much do these cans go for?
Old Aug 5, 2010 | 08:57 PM
H22EG'z's Avatar
Thats exactly what i did, i went to WESCO and got some highbuild primer in a can they are 24.95 or something like that per can.
Old Aug 6, 2010 | 09:03 PM
93h2beg's Avatar
ya in CA it goes for 20 to 30 bucks a can, but know that it will take like 500 cans to do a whole. car, they are meant more for small spots so u dont have to bust out the spray gun and mix up primer then clean ur gun.... just a short cut for small areas.
matmcg
Paint and Body
18
Mar 23, 2008 09:28 AM
Project_EK
Mar 1, 2005 06:26 PM
LANEVOIX
Jan 26, 2003 04:43 PM
zseeanz
11
Dec 13, 2002 08:59 PM
unltdacc12
Oct 19, 2002 11:28 PM
