rattle can problem
Old Jun 25, 2010 | 11:01 PM
AlfieRoach's Avatar
Default rattle can problem
so i sanded my car down, then wet sanded then rinsed dried and started panting and it started to spot and run too any reason why?
Old Jun 25, 2010 | 11:59 PM
gorillafart's Avatar
Default Re: rattle can problem
thats your problem right there, you're using a rattle can... #imjustsayin
Old Jun 26, 2010 | 12:07 AM
AlfieRoach's Avatar
well sorry im not a rich ***** to cough up 300 bucks for a 3 stage and an extra 200 for body work
Old Jun 26, 2010 | 08:58 AM
ej1 rep's Avatar
i dont know probaly the brand of spray can
i recommend Krylon brand, they have by far the widest spray angle Ive ever used, and doesnt leave tiger stripes or anything like that
Old Jun 26, 2010 | 02:13 PM
Eyger's Avatar
Do you have a picture of what's happening? If it's spotting up, it might be fish eyes, which is the presence of oil on the surface of the car. If you use an oil based soap to clean it, you also need to clean the car with a wax and grease remover solvent to get it ready to go.
Old Jun 26, 2010 | 02:37 PM
AlfieRoach's Avatar
THANKS FOR THAT ONE im using acetone after i primer and it seems to be ok
Old Jun 27, 2010 | 12:23 PM
SoCal EJ1's Avatar
This is just too ironic. $300? Really? If that's expensive, then you're doing something wrong...
Old Jun 27, 2010 | 05:35 PM
VERGOTEx3's Avatar
300$ to have it painted or for the paint
Old Jul 4, 2010 | 03:35 AM
hb420's Avatar
Either way $300 is still cheap, never understood why some people can't take some time and save up enough money to get something done instead of half assing ****.
Old Jul 4, 2010 | 03:54 PM
FIST321's Avatar
dont use acetone i dont deal much with spray paint other then trim black. i would think the acetone would make the spray primer soft an start braking the paint down. jsut go the auto parts store an get wax an grease remover. im lying i use high5 is a high build spray can primer maybe u should ook in to that but its not cheap its like 15 bucks a can
Old Jul 4, 2010 | 04:42 PM
prelude1897's Avatar
Why do you have to get a 3 stage, why not get a 2 stage paint, **** or even go cheaper and get a 1 stage paint. Why are you spending $200 for body work, if you're doing it yourself right now? You can even go to the $50 paint job thread and follow that
I agree, cause I can get all the paint supplies to paint a car for less than $300
Old Jul 5, 2010 | 07:52 AM
Dual-500's Avatar
Be careful with the acetone. Nasty stuff and it's highly flammable. Acetone is a commonly used basic ingredient in paint remover so wipe on and off quickly. Make sure the area you are working has plenty of ventilation.
After the wet sand, rinse and wipe with cotton rag. Let it dry real good. The issue is either oil in the paint, or as suggested it's breaking down from the acetone or just incompatibility of the paint and the car finish.
Let the primer dry and prep with scotch brite pad and wipe down. That's your best bet - the primer will act as a blocker.
Good luck with it!
ken9
Paint and Body
11
Jul 11, 2009 09:32 AM
1sckcvc
Jun 28, 2006 07:39 PM
5STAR3
May 6, 2004 10:15 AM
ckkl
Mar 25, 2002 04:43 PM
