quick sanding question
Old Aug 4, 2009 | 01:14 PM
DulinDragons's Avatar
Default quick sanding question
I read the sticky at top, my question is how long do i have to wait after paint job to wet sand the clear coat? I have a couple of runs, and want to fix them. If i waited a few days, would that be ok?
Old Aug 4, 2009 | 06:30 PM
prelude1897's Avatar
Default Re: quick sanding question
Depending on how hot is outside, you should beable to wet sand the next day.
Old Aug 4, 2009 | 07:11 PM
fav6052's Avatar
depends on the clear... when you buy the paint ask for the spec sheet. my pant place gives it to me automatically. tells you ratios, flash time, dry times, tape times, tip sizes, psi to run, etc. ive wet sanded and buffed some of my parts in the same day. there are alot of variables to consider. waiting a day would be best. also try getting a high solids clear. i use ppg deltron 2021.
redrocket94
Paint and Body
10
May 9, 2013 12:57 PM
roadsqueegy95
Paint and Body
Jul 21, 2009 05:17 PM
Si_chRis
Paint and Body
10
Jul 29, 2007 04:50 PM
djtony5
Paint and Body
13
May 27, 2007 10:00 PM
