Primmer pics request!!!!
Old Jun 23, 2008 | 12:25 PM
civicb18Tkid's Avatar
Default Primmer pics request!!!!
ok well i was going to get the ride painted this summer but i decided to get another turbo soooooooooo im just going to primmer it until next summer.
now there are alot of rice bucket primmer cars running around my area so i dont want to be affiliated with them.... so i want to get a nice deep green primmer, satin black primer, or what i really want to do is some crazy design in it.
i would just like pics of cars with dark greem primmer, satin black, or cool designs.
thanks!
Old Jun 23, 2008 | 12:28 PM
Default Re: Primmer pics request!!!! (civicb18Tkid)
even grafitti pics!
Old Jun 23, 2008 | 12:48 PM
DDEVIANT1's Avatar
Get PPG DP series epoxy primer, you can get a killer olive green...Oh and once it is cured, use a little tire shine on it to keep it from chaulking, and yes you will need to remove all of the tire primer and start fesh before you paint it next summer.
Old Jun 23, 2008 | 12:55 PM
thanks for the helpful facts. pics?
Old Jun 23, 2008 | 01:45 PM
dispocrx's Avatar
dont put tire shine on your primer!
before i painted my car
Old Jun 23, 2008 | 02:05 PM
nice crx, and why not?
Old Jun 23, 2008 | 02:22 PM
DDEVIANT1's Avatar
Default Re: (dispocrx)
It is not good for it, that is for sure...but if you plan on keeping the primer on there for that long, you will need to strip it anyways...It just keeps the chaulkiness away, and only use it on epoxy primers.
Primers are not designed to be exposed to UV rays though, and they will break down, not only that but they absorb moisture, and that can promote corrosion over time.
Old Jun 23, 2008 | 05:26 PM
very true. but my cars are always garage kept
PICS PLEASE!
Old Jun 23, 2008 | 08:05 PM
Eyger's Avatar
Not all primers absorb moisture, you can get an epoxy primer that protects against moisture and water. Used for sealing.
Old Jun 23, 2008 | 08:35 PM
DDEVIANT1's Avatar
Default Re: (Eyger)
That is true, but it still wont won't be UV stable, so it still needs to be topcoated...
Old Jun 23, 2008 | 08:55 PM
lol thanks..... I WANT PICS SON!
Old Jun 23, 2008 | 09:43 PM
Mr. EF's Avatar
Default Re: (civicb18Tkid)
if you use a sealer primer you will be fine...i would just go with a quick satin paint job man...its quick and easy to spray and it will be good til you get a good paint job
Old Jun 24, 2008 | 08:20 AM
dispocrx's Avatar
i was also gonna say, you can use a primer/sealer, but like deviant said it wont hold up to uv rays....If you want a nice satin job that will last, then get your color mixed how you want it and add a flatener to the clear!
Old Jun 24, 2008 | 09:45 AM
DDEVIANT1's Avatar
Or go the cheap route and buy hot rod flatz....its cheap and will hold up for considerably longer than primer.
Old Jun 24, 2008 | 10:34 AM
ok im having a garage sale to fund my paint so thanks for the help guys. graffiti pics would still be nice tho
Old Jun 24, 2008 | 11:25 AM
Hovey's Avatar
im rocking hot rod flat black primer. its alright. i m going to redo it and spray flat clear on it. i like it. dont have any good pics of it...makes me wanna go get some
Old Jun 25, 2008 | 07:39 AM
DDEVIANT1's Avatar
Default Re: (Hovey)
HOT ROD FLATZ is a paint and it comes in like 30 colors.
Old Jun 25, 2008 | 08:49 AM
dispocrx's Avatar
i believe its also laquer based...if you want something durable get a a basecoat clearcoat with a flatener...
Old Jun 25, 2008 | 01:28 PM
DDEVIANT1's Avatar
Hot rod Flatz is a urethane based system not laquer.
Old Jun 25, 2008 | 01:29 PM
DDEVIANT1's Avatar
Default Re: (DDEVIANT1)
http://www.tcpglobal.com/kustomshop/ksflatz.aspx
Here is the link they have tonnes of flat colour and it isnt really that expensive.
Old Jun 26, 2008 | 12:41 AM
Mr. EF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DDEVIANT1 &raquo;</TD></TR><TR><TD CLASS="quote"> http://www.tcpglobal.com/kustomshop/ksflatz.aspx
Here is the link they have tonnes of flat colour and it isnt really that expensive.</TD></TR></TABLE>
**** i went a diffrent route and bought some Limco Acrylic Enamel Single Stage and flatened and it was a bit more then 200...Kustom's is way cheaper and i wish i went that route...GHEY
Old Jun 26, 2008 | 05:55 AM
Hovey's Avatar
Default Re: (Hovey)
the dupli colour sandable primer is called hot rod black....i just picked up my paint last night and my flat clear
krazyteg
Apr 14, 2006 12:32 PM
burnout289
Jul 10, 2005 10:22 PM
hondaguyexsi
Mar 10, 2005 05:23 PM
87b16crx
18
Sep 6, 2004 09:01 PM
93LSivic
May 3, 2003 06:50 PM
