Primer with sealer in it.
Old Mar 9, 2009 | 10:18 AM
-16V-'s Avatar
Default Primer with sealer in it.
A guys whats a good decent priced primer with sealer already in it?
I'm confused on on spraying primer then spraying sealer. So i thought i would use one with both.
Old Mar 9, 2009 | 11:13 AM
gorillafart's Avatar
Default Re: Primer with sealer in it.
i use colorbuild primer with a sealer activator from sherwin williams/ autobase line
Old Mar 10, 2009 | 03:49 PM
swappedcx's Avatar
you have primer, or you have sealer. There are numerous types of primers. Acid etc, epoxy, urethane, primer surfacer (urethane), lacquer etc etc etc. Depending on the primer as well, you can have it tinted or in value shades. I know dupont you can use value shades, Sherwin williams you can tint...im sure you can tint almost all of them. But I wont go there.
If you have, per say, a yellow car and you are fixing a dent then painting it yellow again you dont need a sealer. Prime the are with a value shade of around 4 (grey). If you have a black car and you are fixing a area where your primer is white for some reason, you might consider using a sealer with a shade of 6-7 (dupont). If you have a white car and you are doing a overall paint job going to red, I would reccomend a sealer. The sealer will be closer to the color you are trying to achieve helping to get coverage quicker with fewer coats of paint.
Mr2Rotor
Paint and Body
Apr 14, 2013 10:57 AM
eoris__ej1
Paint and Body
10
Nov 23, 2009 04:01 PM
builthatch
Paint and Body
13
May 29, 2009 11:11 PM
aznlaoboi315
Paint and Body
May 6, 2008 08:20 AM
Calean007
Mar 18, 2005 08:47 PM
