PICS: EF Front Bulkhead Replacement
Old May 16, 2011 | 09:16 AM
Jaime 91SiB18's Avatar
Default PICS: EF Front Bulkhead Replacement
Old.
Removing...
Old May 19, 2011 | 05:47 PM
91efbluehatch's Avatar
Default Re: PICS: EF Front Bulkhead Replacement
^your on civic4g.com
whats up!!! love the replacement.
Old May 20, 2011 | 12:46 PM
traderj's Avatar
Interested in how you did the work. What did you remove it with? I would assume you welded it back on. What setup are you using?
Looks like some fine good work. Great job.
Old Jul 21, 2011 | 01:38 PM
Yo! Thank You Sir! Working on getting the paint finished now.
Every spot weld is drilled through only the first layer...
Then an air-chisel is used to seperate the pieces...
Then we fit the new bulkhead by doing any metalwork needed for a factory fit.
Then measurments are taken multiple times to assure correct placement and the new OEM bulkhead gets welded in place.
By "setup" do you mean what welder?
Lincoln wire feed, 120V using .035 flux core. I need to get my bottle filled
to get on the gas and MiG.
Old Jul 22, 2011 | 07:55 PM
coupedragracing's Avatar
Originally Posted by Jaime 91SiB18
Old.
Removing...
just real quick comment for ya.. what u replaced was a radiator support. not a bulkhead.. bulkhead is another term for firewall...
Old Jul 23, 2011 | 03:12 PM
As far as HONDA is concerned......
-It's called the "Front Bulkhead"
Honda Part#60400-SH3-306ZZ
Illustration #005
BULKHEAD, FR
http://www.hondaautomotiveparts.com
-Here is a link to a picture right out of the manual pictured above...
http://www.tenbytencustomcarbon.com/#!__front-bulkhead-replacment
Old Jul 24, 2011 | 11:33 AM
Oh well never heard it called that guess just hondas.
Old Jul 24, 2011 | 04:13 PM
CARNAG3's Avatar
good thing you quoted all the pictures or I wouldn't have known what you meant
Old Jul 24, 2011 | 04:55 PM
greenek's Avatar
what points did you measure to make sure the bulkhead was perfectly lined up and in spec? I have an ef myself that I just got back from a shop for a minor fender bender.
Long story short, im gonna order a new bulkhead and throw her on.
Old Jul 25, 2011 | 12:24 AM
Originally Posted by greenek
what points did you measure to make sure the bulkhead was perfectly lined up and in spec?...
I added that pic for you here..
Old Jul 25, 2011 | 05:02 PM
greenek's Avatar
very much appreciated
Old Jul 27, 2011 | 06:28 AM
I'll have a whole detailed write-up done soon available at that link
Old Jul 27, 2011 | 05:43 PM
greenek's Avatar
subscribed.
ill keep an eye on this thread and definitely check it out once you finish
Old Dec 11, 2011 | 04:41 PM
carbonfiberhb
Apr 19, 2008 09:00 PM
punkhop83
Mar 20, 2005 10:46 AM
brad.
Mar 15, 2005 02:24 AM
Serio*Ferio
Apr 3, 2004 06:02 PM
TrevorHiroshima
Jun 4, 2003 05:48 PM
