noob question - is this compressor good enough?
Old Nov 22, 2007 | 08:37 PM
hyper em1's Avatar
Default noob question - is this compressor good enough?
Looking into getting a compressor to start teaching myself how to paint on my project car... going to do an integra in the long run, but it can be part by part. Is this one any good or do i need more power? BTW, I dont have a paint gun yet, so maybe id have to use a hvlp or some other gun based on the power? any input is appreciated. TIA
http://www.sears.com/shc/s/p_1...2000B?
"Craftsman 33-Gallon 1.6-hp Vertical Air Compressor with Tool Accessory Kit
Largest air tank for more air tool runtime than any competitive retail compressor. New pump and motor delivers 4.9 scfm at 90 psi per ISO1217. Lower start-up for fewer tripped breakers. Use with any 120-volt extension cord up to 50 feet. Quieter running at 78 dBs. Vertical Wt.146.3
" from sears website
Old Nov 22, 2007 | 11:06 PM
ek4shizzle's Avatar
Default Re: noob question - is this compressor good enough? (hyper em1)
id say its too weak to paint, but you can get by. i use a craftsman 15 gallon 1.5 hp and i do whole cars, but it lags like hell. if anything dont get a craftsman. its ****. loud as hell too. get something with more hp and more cfm.
Old Nov 23, 2007 | 11:01 AM
Pockets's Avatar
2 stage is what you want
Old Nov 23, 2007 | 08:33 PM
hyper em1's Avatar
Default Re: (Pockets)
im gonna take a look at harbor freight see what they have i guess
Old Nov 25, 2007 | 06:15 AM
Lubo_25's Avatar
if you want to paint your car nicely aim for something around 50 gallons or so more is better in this case and a good filtration system for the oil and moisture cheers
Old Nov 25, 2007 | 07:26 AM
powerflow's Avatar
Default Re: noob question - is this compressor good enough? (Lubo_25)
If you want to be able to paint/clear a whole car or many parts at once you will most likely need a big *** 2 stage, 220 volt compressor.
Old Nov 27, 2007 | 07:08 PM
Team Rukus's Avatar
minimum requirement for a proper paintjob should be 7.5 hp 60 gallon 2 stage 220v copressor.
anything smaller then that will take along time for the compressor to build up air and the longer it takes the weaker the gun is and the weaker it is the shittier the paint.
mind you i have done paintjobs with 2.5 hp compressors and it came out amazing (just not worth the time and alot of waste material while painting). the shittier the compressor the more materials you will be wasting ie. clear, base etc...
Prototype1994
Paint and Body
Jul 24, 2016 04:36 PM
colts0455
Paint and Body
Jan 5, 2013 06:49 PM
CPreston
Paint and Body
May 2, 2009 11:18 AM
blaze.1
Paint and Body
Feb 26, 2009 07:16 PM
joblow
Mar 15, 2003 07:28 AM
