need some help on DIY
Old May 24, 2007 | 11:18 PM
diewnaylomoah's Avatar
Default need some help on DIY
this is goin to be my first time doing anything like this. so all the info will help.
i wanted to know what brand name bondo i should use and what kind?
how much would a ok spray gun cost?
how much would a compressor cost. (one not too expensive)
Old May 25, 2007 | 04:01 AM
WihaSi's Avatar
Default Re: need some help on DIY (diewnaylomoah)
The filler I use/like is Evercoat http://www.eastwoodco.com/jump...age=3 I hear the Rage Xtreme is good.
An "ok" spray gun you can get for like $125-$250
A compressor is going to be expensive, not too sure on prices. I myself haven't even bought one yet. Best thing to do would be to search websites like Sears, Lowe's or Home Depot...or actually visit the store.
Old May 25, 2007 | 05:00 AM
alltech_hybrid's Avatar
Default Re: need some help on DIY (WihaSi)
A quality compressor that will be able to hold enough cfm for auto painting is not going to be cheap.. You need around 14cfm for painting with hvlp guns and if you do some research you will see that the higher cfm the compressor holds the more expensive... i say AT LEAST $6-$800 for the compressor... Guns range from $75 cheap crap to almost $400 a gun... but Devibliss has great starter guns for a good price
Old May 25, 2007 | 10:48 AM
whats the difference btween filler and bondo?
Old May 25, 2007 | 11:20 AM
WihaSi's Avatar
Default Re: (diewnaylomoah)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by diewnaylomoah &raquo;</TD></TR><TR><TD CLASS="quote">whats the difference btween filler and bondo?</TD></TR></TABLE>
No difference. I think bondo is a brand of filler (like Evercoat). The actual material is usually called "plastic filler."
Modified by WihaSi at 3:33 PM 5/25/2007
Old May 25, 2007 | 12:10 PM
92LSVTEC's Avatar
Default Re: (WihaSi)
bondo is no longer used. it was a different make up of what is now called filler, but in lehmans terms, is called bondo.
Evercoat FTMFW!! all thier stuff is good. make sure to to the final 'bondo' in evercoat glazecoat. best stuff on the market. doesnt pin hole much.
Old May 25, 2007 | 03:48 PM
92BluEH-3's Avatar
lulz
Default Re: (92LSVTEC)
if you get a compresser be sure to get a air/water seperator. not sure on the exact name that might be it but, you will definatly want one. Paint+Water=Bad Paint
emooheo
Paint and Body
Jun 9, 2010 07:05 AM
Dxs
Paint and Body
10
Dec 28, 2007 08:39 AM
K20A_EH
Paint and Body
35
Jul 15, 2007 11:28 AM
diewnaylomoah
Paint and Body
May 25, 2007 04:41 AM
