Need some advice
Old Mar 8, 2016 | 08:15 AM
buster97's Avatar
Default Need some advice
About 2 years ago my car was 3/4 different shades of black . Took it to a shop guy charged me $700 to smoothen out some body issues and lay down some fresh black paint (clearcoat base coat style of paint)
Now my problem is i didnt drive the car and let it sat outside for a year and a half ended up with terrible oxidation (living in the desert). There is also hives like cracks all over my roof prob fit the end of a toothpick in them and also showing "crow's feet" on other sections.
Took it to him to ask why it happens told me because i didnt drive and wash the dirt off this happens and the heat just eats it away. Told me he will sand and reshoot it all for $500 but suggest i go with a different color.
Now my question is this guy bullshiting me or telling me the truth ? What really happen to my paint if he is lieing
Ill post pics up later if needed
Old Mar 9, 2016 | 06:47 PM
gorillafart's Avatar
Default Re: Need some advice
oxidation will come from the sun. but just after a year and a half, that must mean it was a cheap quality of paint.
the crows feet and cracks, means the paint he sprayed had a reaction to the paint that was on your car be4. meaning he needs to sand it good and use sealer before spraying anything else.
Old Mar 9, 2016 | 11:37 PM
JDMswagSerf's Avatar
Shit Posts: 15
10 Year Member
The guy is bull shitting you.
The clear coat has failed due to improper application.
Did the roof need any bondo work?
If you can fit a toothpick in the crack, it is most likely seperated bondo.
Crows feet is from as mentioned above. A reacrion to the surface underneath.
Old Mar 12, 2016 | 06:04 AM
buster97's Avatar
No bondo work on the roof only rear quarter panel.
Thanks for your input guys i got a air compressor and gun. Going to try to repaint it myself.
For my situations is it best i sand as deep as i can?
Edit-Whats better for "flexing" and sitting in the sun base coat clearcoat or single stage?
Old Mar 12, 2016 | 07:06 PM
Shit Posts: 15
10 Year Member
Nice! I started out in the garage and now I'm a damn good painter.
Just watch videos online or post questions or send me a pm and I'll help you out.
If you want the paint job to last. Sand It down to bare metal and primer over the body.
As fast as durability. Base coat/clear coat every day.
If you want the paint to hold up you can just said it till the body is smooth but after a few years it will fail. The base coat on the car is no good now.
NEO_FOLLOWER2
Mar 21, 2011 11:55 AM
projectef
Paint and Body
Jul 11, 2008 12:26 PM
Dly989
Dec 6, 2005 01:57 PM
ascendo2
Sep 17, 2002 09:05 PM
lazyvietboi
Dec 16, 2001 04:10 PM
