kandy help
Old Dec 5, 2008 | 10:15 PM
C-187's Avatar
Default kandy help
gotta do a kandy on monday or tuesday but ive never done one. i know you have to walk the car. ive herd that the fist couple of coats will look moldely. any help will be apprecaired
Old Dec 9, 2008 | 11:47 AM
sleepencivic's Avatar
i've done 2 kandy jobs its not that bad...keep the coats light and even i did 2 coats silver base (some like to use black) 4 light coats of kandy color ( if you get a run you have to sand the whole side with the same grit and re-due dont just sand one spot you will se it), 3 coats of clear came out good...keep the coats as even as possible and dont do a drop coat(final mist) like you do for metalics.
Old Dec 10, 2008 | 09:14 AM
crapanese's Avatar
ive only done 1 candy and i agree with what was said above, i had a little more of an overlap than normal but the job wasnt as bad as i expected. light coats / heavy overlap, dont run or sag it and you're
shawnlee250
Honda Civic (2001 - 2005)
10
Jan 11, 2012 12:39 AM
cats_on_ice
Jun 4, 2006 05:26 PM
madlion
Sep 8, 2004 10:26 AM
anewfoundkevin
Apr 15, 2004 12:07 PM
naChoGun
Feb 7, 2002 01:11 PM
