how much paint
Old Mar 12, 2015 | 11:05 AM
widewhite's Avatar
Default how much paint
ok guys I am wanting to have my car repainted, from your experience how much basecoat does it take to paint a integra 2 door, not including jams since it is going to be same oem color bg-33p. mainly painting bc of fade and clear coat of a 1994 integra as you can imagine the original paint is tiast on top of hood roof deck lid.
I plan on buying a gallon of clear coat and quart of hardner, so I can hopefully clear more than once to make her shine, but I really want to know your opinions on how much basecoat it will take.
also would a pint be able to cover a hood for a different integra?
Old Mar 13, 2015 | 04:22 AM
jlk16188's Avatar
Default Re: how much paint
if you are painting yourself and have never done it before you will most likely have to touch up some areas or respray some drips and sags. Buy 1/2 gallon of base coat to do the car minus jams and engine bay.
Old Mar 13, 2015 | 04:28 AM
widewhite's Avatar
thanks I wont be spraying myself, I have a painter, he just wasn't sure on how much it would take cause he hasn't painted and small car in awhile.
Old Mar 29, 2015 | 09:36 AM
Hidenplanvew's Avatar
1 Gal will usually cover a car including jambs (depending on mix ratio), Like Deltron or Global Its 1:1 so you usually have 2 gals of spray able material. Its nice to buy in a gal so you can get the whole car done in the same color and you might have a little left over for touch up's. You want to do about 3 to 4 coats of clear so a gal should cover it all.
Just an example, on a Camaro I did we had to do 2:1 mix ratio because the color was to transparent and ended up having to use 2 gals of base.
crxsir23
Paint and Body
Feb 24, 2010 06:12 PM
dc4teg95
Paint and Body
Oct 15, 2009 04:56 AM
JDMinspiredDA9
Paint and Body
Feb 26, 2009 12:01 PM
ctownintegra
Jan 31, 2007 07:43 PM
