Help primer prep ????
Old Sep 2, 2007 | 09:07 AM
B Series JuNky's Avatar
Default Help primer prep ????
im getting ready to primer my car but i have no idea in what i need to get it ready for primer what grit sand paper would be best to get it started anyhelp would be great thanks.
Old Sep 2, 2007 | 09:18 AM
Default Re: Help primer prep ???? (B Series JuNky)
anybody ??? i would like to get it started today please anyhelp
Old Sep 2, 2007 | 10:03 AM
heeelp
Old Sep 2, 2007 | 11:40 AM
wooow no help on this o'well
Old Sep 2, 2007 | 01:38 PM
b20powereDA's Avatar
are u just trying to sand it and prime it? also, aree u priming the whole car?
Old Sep 2, 2007 | 04:00 PM
Default Re: Help primer prep ???? (b20powereDA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20powereDA &raquo;</TD></TR><TR><TD CLASS="quote">are u just trying to sand it and prime it? also, aree u priming the whole car? </TD></TR></TABLE>
yes im just tryin to sand it and prime it im just doing the two fender's and the bumper
Old Sep 2, 2007 | 05:11 PM
i would say tio make sure to finsih it with 320 grit sandpaper. some people say 180 is fine but i would say to go with 320.
Old Sep 2, 2007 | 07:00 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20powereDA &raquo;</TD></TR><TR><TD CLASS="quote">i would say tio make sure to finsih it with 320 grit sandpaper. some people say 180 is fine but i would say to go with 320. </TD></TR></TABLE>
so start it and finish it with 320 or what ??
Old Sep 2, 2007 | 07:09 PM
msinsky14's Avatar
i use 320, then wax/grease remover to lift off any sanding dust or wax and grease, then tack cloth, and spray primer.
Old Sep 2, 2007 | 07:25 PM
Default Re: Help primer prep ???? (msinsky14)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by msinsky14 &raquo;</TD></TR><TR><TD CLASS="quote">i use 320, then wax/grease remover to lift off any sanding dust or wax and grease, then tack cloth, and spray primer.
niice thanks for the help
before i answer any more questions, what is the reason for priming the panels? is their some damage on the panels? if so have u already repaired the damage?
Old Sep 2, 2007 | 07:42 PM
msinsky14's Avatar
before i answer any more questions, what is the reason for priming the panels? is their some damage on the panels? if so have u already repaired the damage? </TD></TR></TABLE>
prolly damage on his. if i used filler, i spray high build on the entire panel, which removes waves in the panel as well. then a urethane primer to seal, the more wax/grease remover, tack, and paint
like on my current crx after i get it back from getting new quarters welded, im gonna lay high build over the hole car, especially doors, to get rid of that waviness.
but if theres no body work and panels look straight, just scuff the paint with 500 and paint
Old Sep 6, 2007 | 03:32 PM
i didnt have to do no body work or nothing the fender's are clean just sanded them down and spryed them they look pretty good thanks for the help .......
MacDuff
Feb 6, 2008 03:54 AM
pfcle
Honda Civic (2006 - 2015)
May 30, 2007 09:13 PM
BSpoolinHatch
Apr 22, 2006 08:02 AM
aaronISthrowed
Mar 11, 2006 05:59 AM
Glai1628
Feb 15, 2004 01:47 PM
