Help needed to remove rust and do touch up paint
Old Feb 28, 2013 | 05:13 PM
azi90's Avatar
Default Help needed to remove rust and do touch up paint
I have few little rusted spots(size of smaller than pennies) on front of hood. i want to get rid of rust on them and than do a touch up paint job.. what do i need to do ?? i know i need a sand paper and than color for my car.. but would i be able to get exact color i mean merge the touched up part with my original hood paint ?
Old Feb 28, 2013 | 07:29 PM
01_civic's Avatar
Default Re: Help needed to remove rust and do touch up paint
not unless you're some type of paint pro... you're better off just sanding, touching it up and adding a layer of clear.
Old Mar 1, 2013 | 07:08 AM
azi90's Avatar
ofcourse i was talking abt doing the touch up .. i was asking if the touchup will merge with the existing paint or will it stand out?
Old Mar 1, 2013 | 03:48 PM
azi90's Avatar
bump
Old Mar 1, 2013 | 04:44 PM
grumblemarc's Avatar
The Grumpiest
What do YOU think? New paint over old worn paint?
Old Mar 1, 2013 | 04:54 PM
azi90's Avatar
ok so it will be shown ? i HAVE to cover those lil marks or else it will keep getting rusted.. how do i do it without its being obvious that i did touch up
Old Mar 1, 2013 | 04:55 PM
The Grumpiest
YES!!! It will be obvious. If you don't know how to blend the paint new to old then take it to a shop.
Old Mar 1, 2013 | 06:01 PM
azi90's Avatar
and i cant do it myself ? i dont wanna pay any one for something so small.. im sure if i can get some advices on how to merge my old paint with new paint i dont need to pay someone else to do it
Old Mar 1, 2013 | 06:04 PM
The Grumpiest
I don't know what you can do.
Old Mar 1, 2013 | 07:43 PM
Hidenplanvew's Avatar
Its called blending, Feather edge the damage, you going to need 18" from the center of what your painting on each side. You Paint it with a wisk of the wrist to get alittle overspray past the repair, then you need to do a fog coat, about 12" above the panal with a 90% overlap. Your going to need to re clear the whole panal, From here there isnt much more I can tell you.
Old Mar 2, 2013 | 06:38 AM
azi90's Avatar
thank u for ur generous help
Old Mar 2, 2013 | 06:40 AM
azi90's Avatar
i think u guys are not getting clear picture of wat im saying .. i need to fill in little chips that u get on ur hood from highway... its not like im doing a big painting job i just need to fill those little tiny marks that u get from little stone particles on highway
Old Mar 2, 2013 | 08:52 AM
The Grumpiest
Doesn't matter if it's one chip or a hundred. You still have to know how to blend the new paint into the old.
You're the one that's not getting it.
Old Mar 2, 2013 | 09:50 AM
azi90's Avatar
ill if u know how to talk nicely to ur fellow forum member
Old Mar 2, 2013 | 11:41 PM
eat,sleep,...'s Avatar
This Forum is awesome! wish i would have joined yrs ago!
Paint jobs are Expensive because it requires skills that can't be learned overnight. not to mention proper tools and equipment $$$. this also applies to "touch up" jobs where paint is expected to match. So, no your paint won't match if you do it your self. But I say do it anyway and let it be a learning experience! And post up some photos!
Old Mar 3, 2013 | 06:48 AM
azi90's Avatar
i was thinking to follow this .. http://www.ehow.com/how_5959544_blen...tches-car.html what do u think
Old Mar 5, 2013 | 09:22 PM
Sounds easy, right? Only thing is. . . It's not. But I like the way step nine says "should"!
Old Mar 6, 2013 | 08:13 PM
Horrible info, You should be using wax and grease remover not soap and water. Also you should use a tac rag and blow, tac, blow and they apply paint not use a "cotten rag"... That is someone who dosent know how to paint! Also you dont want to apply wax over fresh paint for 2-4 weeks.
tmramsburg
Paint and Body
Jul 28, 2008 01:14 AM
scorro1
Apr 26, 2006 01:14 PM
AZNracerx1989
Dec 6, 2005 11:35 PM
InTeGrA_bLazEd
Mar 25, 2004 02:53 PM
Integra187
Jan 8, 2002 03:23 AM
