help a bro. out
Old Nov 3, 2009 | 10:58 AM
jhendry's Avatar
Default help a bro. out
k so i've done LOADS of research and think with a few weeks of practice i can paint my car. now the time has come to find a decent gun and decent paint the rest is taken car for the body work supplies. oh except for a good filler for very minor holes so give me your recomendations
I need a HVLP gun
Good paint brand
and good body filler (very minor things such as door ding and a small spot where rust USED to be)
and my budget is around 200-300 for now but i could save up more if need be.
and i'm sure not all guns and paints were created equally so let me know
Old Nov 3, 2009 | 03:12 PM
gorillafart's Avatar
Default Re: help a bro. out
for your money... iwata or devilbiss will suffice... if u got more money... Sata
for filler... i use evercoat theyr'e the best IMO. door dings/scratches/wavyness you'll probably only need metal glaze. an actual dent.. use quantum or rage gold/xtreme
Old Nov 3, 2009 | 03:24 PM
jhendry's Avatar
k i'll look into those i've heard of devilbliss. awesome i'm hoping to do the work on the car then seal it once i get the gun.
but what changes on the gun from brand to brand? well made-ness? functionality ? or nicer tips? just wondering..
Old Nov 3, 2009 | 04:51 PM
jcdimvic's Avatar
i can personally vouch for the devilbiss guns. works great I dont have any complaints for the price that i paid for them. Summit runs good deal on em every so often, check em out. Evercoat in my opinion is the best bang for the buck when it comes to fillers.
Old Nov 3, 2009 | 08:03 PM
jhendry's Avatar
k thanks guys i'm looking into guns tomorrow and checking out local stores and lots of people have recommended evercoat. so i think thats what i'll use and i decided to go with championship white for color.
Old Nov 4, 2009 | 10:18 AM
christmastree's Avatar
Ya definitely evercoats "rage". I have never used anything better. And I shoot with sata and iwata and love both but my preference is iwata. I really like the lph-400. However you will be spending nearly double what you want. I have never checked to see if either brand has a gun in your price range but I would assume not considering what I spend on mine.
Old Nov 4, 2009 | 11:56 AM
dreamreaperx's Avatar
i can vouch for devilbiss starting line, it's a cheapy gun, but i have done some work that has come out amazing with it...i also have an iwata, and this thing lays down clear like glass if shot properly
Old Nov 4, 2009 | 06:47 PM
Spawne32's Avatar
evercoat zgrip, evercoat metal glaze for your body filler and metal glaze, for small dings you can use just the metal glaze. If your color matching go with PPG/Diamont, if your painting the whole car you can go with Limco which is an excellent paint on a budget, its what im using, the 4100 high solids clear is excellent. As far as primer goes, limco 2k primer works great.
Old Nov 4, 2009 | 08:59 PM
jhendry's Avatar
ok so thanks for all the advise. but i looked around and i think i can afford a devillbliss starting line one but i may get lucky on some other brands i was looking around online and i'll check the classifieds tomorrow. so i found one and it said good for priming
im assuming thats becuase of the big 1.8 tip. so could i just clean that then get say a 1.4 or 1.3 for my base coat?> and how much will a new tip cost ? and do i have to get a Devilbliss tip or is it a universal fit?
Old Nov 4, 2009 | 09:08 PM
Spawne32's Avatar
get the technical data sheet for the base coat and the clear coat when you buy your supplys, that will tell you what nozzle to use
Old Nov 4, 2009 | 09:40 PM
jhendry's Avatar
ok that sounds good i'll be running to a few paint shops to see whats available. what is the average price of a tip?
and is it the tip or the gun that says if it's good for thick or thin paints?
when i saw kits for sale they had multiple gun instead of multiple tips, why is that?
my main question is, can i get away with buy only one gun and maybe 2-3 tips??
Old Nov 4, 2009 | 09:42 PM
Spawne32's Avatar
tips alot of times wind up being painter sensitive, specs may say to paint with a specific size but i know alot of painters that like using one particular size for their paint work, and they still get excellent results.
Old Nov 4, 2009 | 09:48 PM
jhendry's Avatar
i read a page that said i might need a gun for my clear coat too?
i plan to practice for quite a while before i attempt to paint my D.D. so i will have time to experiment with tips.
so can i get away with only buying one gun? but with tips?
Old Nov 4, 2009 | 10:03 PM
u can use the same gun for base and clear... if the paint and clear are same composition... im in LA county where u can only buy waterbase now... so my base gun is waterbase... but my clearing guns still spray enamel/solvent. i have two different guns for the two different compositions of material... but if you were spraying solvent base and solvent clear... u can use the same gun for both.. just clean be4 u spray clear...
i believe between the different paint guns, a certain brand will give you better results, but at the same time it can be user specific... i prefer sata but they're the most expensive. so it comes down to what you can afford. as far as different tips go.. i'd stick with a 1.3 or 1.4 no more... maybe even a 1.2...
Old Nov 4, 2009 | 10:16 PM
Spawne32's Avatar
california is the plague of the planet, now they wont even let you paint your car with anything but waterbase paint?
Old Nov 5, 2009 | 11:23 AM
Ya I would definitely just buy one good gun (I personally would get a 1.3 tip). You can spray anything through it (primer, sealer, base, clear, epoxy). And as long as you clean it well and take care of it it will last you a loooooong time
Old Nov 5, 2009 | 12:33 PM
shocker911's Avatar
evercoat filler
PPG paints
if your really not going to do this alot usually paint store have a brand called "starting line" 100 bucks for a decent paint gun and a ok touch up gun
Old Nov 5, 2009 | 12:58 PM
jhendry's Avatar
hey thanks for the advise every one, i looked at the devilbliss starting line paint guns. and read some reviews, seems people have had good results with them and nobody had any thing terrible to say about them..
if i find down the road half a year or so that i can do a good job painting. then i might get a better gun but i think this is a good starting place.
85_305
Paint and Body
23
Oct 7, 2012 09:10 PM
hybridmiklo
Paint and Body
11
Jan 5, 2009 01:28 PM
Traction
Jun 1, 2004 09:14 AM
JackAcc
114
May 5, 2004 03:57 PM
SjCiViCHB
Feb 20, 2002 02:50 PM
