Fixing a bashed in fender
I hit a tree, long story short.. my fender is just bent in with a cut in it. Whats the best method on pulling the dent out? Any help is appreciated
Oh yeah, first thread in Paint/Body FTW
You could if it isnt to bad just take it iff and use a rubber hammer on the back. then thin layer of bondo of needed.
2nd reply in Paint and body FTW!
Ive used bondo with success....only problem was I hit a mail box and the bondo cracked. Id be interested in trying another form of body filler though.....what is USC or Metal glaze??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YoUvegOtMaiL »</TD></TR><TR><TD CLASS="quote">Ive used bondo with success....only problem was I hit a mail box and the bondo cracked. Id be interested in trying another form of body filler though.....what is USC or Metal glaze??</TD></TR></TABLE>
There is info in these two posts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by [b]<u>Engine Bay "Icing" or "Filler" »</TD></TR><TR><TD CLASS="quote">USC ICING
Slappy: "I think that's what (Bryan) Pandahatch used.......Ive heard good things about that one."
OR
Link for Evercoat Metal Glaze:
http://www.evercoat.com/productDetail.aspx?pID=1
Pic for Evercoat Metal Glaze:
http://www.evercoat.com/imgs/p...e.jpg </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by [b]PandaHatch on <u>Fillers/Bondo... »</TD></TR><TR><TD CLASS="quote">DO NOT USE BONDO!!!!!
There is USC Icing and Evercoat Metal Glaze. Take your pick, they're essentially the same.
I did ALL my sanding by hand, except for the core support otherwise I used a DA, EVERY contour is and done, I feel when working with complex shapes, you can get a better feel with hand.</TD></TR></TABLE>
OR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by John M »</TD></TR><TR><TD CLASS="quote">I have heard of the metal glaze but thought it was only to fill in light scratches in the metal. Like little gashes.</TD></TR></TABLE>
Most people are using it on their engine bays to fill small spots (such as spot weld dimples) and seams. I haven't heard any compaints yet. My Paint/Body issue of Hot Rod Magaizine also recommends it. Peeps say it's easier to work with and easier to sand.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ilsimsli »</TD></TR><TR><TD CLASS="quote">fenders arent worth fixing just replace it there cheap
btw paint and body forum </TD></TR></TABLE>
x2, i replaced both my fenders recently, easy to do and cheap.
time is money, and fixin it might take a lot of time if you dont know what ur doin. I would just get a used fender u never know you might even get one the same color as ur car.
metal glaze can fill some pretty deep scratches or some minor minor door dings from cars! but tap out the dent some with a hammer first before using metal glaze! the less filler the better!
First it needs to be pulled out. Then weld the hole shut, if you dont weld it shut the filler will absorb moisture and crack. MUCH MUCH easier buy a new fender for like 20bucks
