Dirt under primer. What to do
Old Nov 9, 2010 | 05:51 AM
boostedb20ek's Avatar
Default Dirt under primer. What to do
So I have a project car n my garage that I am completely restoring. I've painted engine bay 3 times until I got it the way I want it. I'm a rookie at this so it took a little while to get used to the gun and the feel for everything. Well last nite some how I forgot to wipe down the car before spraying (idiot, and I have 2 gallons of prep all sitting there jus for that), so there was sanding dust on car when I started to primer. Only sprayed rear quarter panel before I realized and slapped myself, now what? Do I need to strip the primer and start over or do I sand it smooth again. Thanks
Old Nov 9, 2010 | 05:56 AM
redmanjd's Avatar
Default Re: Dirt under primer. What to do
I personaly would sand it down out of fear for the paint flaking off because it could not adhear to the metal becasue of the dust. especially if its just one panel.
Old Nov 9, 2010 | 08:23 AM
DA9parling's Avatar
sand it all down bro ! only way it will look good and last
Old Nov 9, 2010 | 09:12 AM
Back to square one. Lol. Hate doin double work but hate being unsatisfied more. Time to start sanding.
Old Nov 9, 2010 | 10:00 AM
DA9parling's Avatar
haha i know what your going threw...
check my paint work i did on my da lol its rattle can but hey it looks good
goodluck on the paint bro
Old Nov 9, 2010 | 10:36 AM
Dayum... Rattle can shinnin. Lol. I'm a pretty patient person. I would much rather do it as many times as needed than to have a fugged up paint job. Thanks. I'll post up pics in my build thread when it's done right
Old Nov 9, 2010 | 11:34 AM
DA9parling's Avatar
yeah its shinnin lol
Old Nov 9, 2010 | 04:46 PM
Dontoh's Avatar
just block sand it, it's no biggie. it'll be smoother anyway and look that much better
Old Nov 10, 2010 | 03:38 AM
^^ r u saying jus to smooth it out, kinda sand the dirt off but not all the way back down to it's original color, I know the primer is bonded real well to the car cuz its not coming off to easy with 80 grit.
Old Nov 10, 2010 | 04:27 AM
Dontoh's Avatar
i wouldn't use 80 grit on primer, but then i again i don't know how far along your body work is. i'd block sand it with 180-220
Old Nov 10, 2010 | 10:08 AM
DC2.2_GSR's Avatar
I'm so confused by this...
Dirt underneath primer doesn't matter at all. Primer always gets put on heavy and thick and then must be block sanded smooth. Primer is nothing more than the last step in body work. When priming, you only need to make sure the surface is free of wax or grease and there are no pinholes in the body work... other than that, primer can be sloppy. You don't need to worry about dust when priming.
If you're talking about sealer - the first liquid step in paint work - then yes, dirt underneath the sealer is a problem as it will show through into the base and then appear as a nib in the clear coat. some dirt nibs are okay to have with certain colors because you can easily wet sand them out of the clear.
If you have a ton of dirt under the sealer that you're sure will be an issue later on, then just make sure it's cured all the way (the product's tech sheet will tell you how many hours until re-sand) and then just re-prep the surface with whatever grit you're using on the DA for prep. I would just re-sand it with 400 grit on your DA and then *blow it off and wipe it down* and then re-seal it then go from there. You don't need to remove anything, just sand out the dirt nibs and sand the rest of the area smooth, then scuff the rest... it's standard prep work again once the sealer is cured.
I don't know where some of this nonsense comes from but some of you should really hold off on the advice-giving until you know what you're talking about.
Old Nov 10, 2010 | 04:41 PM
Dontoh's Avatar
many people prime>scuff>seal>base>clear, i know its not proper but its been done
Old Nov 10, 2010 | 05:47 PM
DC2.2_GSR's Avatar
People have also painted cars with Rustoleum. I've even heard of a guy making rust filler panels with paper mache. Both are just as stupid as only scuffing primer before paint. It's purposely ruining a paint job. No matter how finely you try to atomize the primer, it's a thick material which will build on the surface and only amplify the imperfections underneath.
Primer is only applied to a surface that you wish to remove imperfections from. You apply it thick with the intent to block sand it smooth. There's no other proper use of primer. Like I said, sealer is applied as the first step in paint work, which at that point is over a perfectly smooth surface. There are a few materials companies out there who market a 'multi-option' primer product, like Keystone's 3-in-1 primer surfacer/sealer, but it's not a true sealer that's made to work wet-on-wet in a paint system. Those 'sealers' are just thinned down surfacer which will still need to be blocked out or as least machine sanded before it's smooth enough for paint.
Standard Operating Procedures do not vary greatly between equally competent professionals. No matter what shop you walk into, you will always see primer being used as a surfacer to be block sanded in preparation for sealer and base. Anyone who does it any differently than that is ruining a paint job either out of incompetence or laziness or both.
Old Nov 10, 2010 | 06:47 PM
Dontoh's Avatar
i understand that, i work in a custom truck and rod shop- i know paint. i'm just explaining that not EVERYONE has the same procedure. when i first started painting, i primed>scuffed>painted so i understand where the op is coming from.. i'm not saying that you're wrong, i'm just trying to make sure you understand what op is doing
danteisme
Paint and Body
Feb 11, 2019 08:56 AM
evil_ryu
Paint and Body
Oct 30, 2009 05:46 PM
preludexl
Welding / Fabrication
Jan 17, 2005 11:33 PM
Si Arn
Jun 3, 2003 11:56 AM
redteg1
Jul 6, 2002 08:11 PM
