did some bondo work "1st timer"!
Old Dec 9, 2009 | 02:44 PM
ed4doorcivic's Avatar
Default did some bondo work "1st timer"!
Well This wa my 1st time applying bondo and I did enjoy it, I love the fact this puddy will erase all dings or small dents, I have a few pics so enjoy
on Dec 7th i did bondo for the first time, it was pretty simple just alot of sanding, I guess the car was in a hale storm cause there was a bunch of dings on the roof and trunk and hood, I havent done the hood yet but I am going too. Plus I got a new windshield wiper switch, my other one would sagg and turn the blades on when I didnt want them on "that got old fast" well here are some pics
That's it, I have to sand some high spots on the roof and do the hood, and I have like 4 small dings around the body to get, I am sicked that there are no more dings in the roof now, I took the headliner out to pop the big dents up so the roof wasnt weak, and bondo! Oh yeah u see that loaner rim blinging in the last pic RIGHT!!!
Old Dec 9, 2009 | 03:01 PM
4drEF's Avatar
Keyboard Humorist
Default Re: did some bondo work "1st timer"!
Pics make it look like you have Bondo over your paint.
If so, grind it off and try again.
Should be on bare metal.
Old Dec 9, 2009 | 03:06 PM
I went to metal, sanded ALOT!
Old Dec 9, 2009 | 03:11 PM
knightsef-eg's Avatar
as long as you sanded a 1-2 inch area larger than the problem you were fixing should be ok ...
Old Dec 9, 2009 | 07:31 PM
prelude182's Avatar
i never really sand down to bare metal when i bondo. Turns out fine. One thing you want to make sure tho is when your sanding the bondo down that it is smooth to the touch, you dont want any bumps or it will show up in the paint and you will get pissed.
Old Dec 9, 2009 | 07:33 PM
prelude182's Avatar
also get your hands on a D.A. sander. its way easier and less time consuming.
Old Dec 9, 2009 | 07:42 PM
Clipsed's Avatar
Yea I was going to say. I would also recommend Rage Gold, it's a lot better filler, and has better flex capabilities. As for the roof, do you know if the skeleton has collapsed? If so, that bondo will crack in no time.
Old Dec 10, 2009 | 01:05 AM
sde780's Avatar
I hate working with Bondo. I can never get it to blend in perfectly
Old Dec 10, 2009 | 06:17 AM
Aftermath_Hatch's Avatar
When your done you might wanna hit that with some primer,but besides that looks like you did a pretty good job.
Old Dec 10, 2009 | 07:56 AM
Well it is sanding pretty damn close, Im using a stirring stick for paint, and wrapping the middle with sticky sandpaper, and go in different motions across the bondo, it actually works REAL GOOD! my step dad gave the idea,
cause I was sanding with my fingers and sandpaper but it leaves waves so that didnt last long.
Old Dec 10, 2009 | 08:10 AM
thanks dude, I have primer but I got primer "FILLER" so it is a **** ton of sanding to get that stuff off, I need to buy some 96 cent walmart primer for now.
Old Dec 10, 2009 | 09:23 AM
Jenkinsal2's Avatar
No you dont. Do some reasearch and prime and piant those spots correctly or the bondo will soak up moisture and rust underneath.
Old Dec 10, 2009 | 10:57 AM
grog's Avatar
Originally Posted by Jenkinsal2
prime and PAINT those spots correctly or the bondo will soak up moisture and rust underneath.
x2, too many repairs finish at the primer stage, neglecting to paint it will leave the door open to rust, as primer absorbs moisture.
looks good so far.
Old Dec 11, 2009 | 05:43 PM
Eyger's Avatar
The "filler over paint" debate has been going on forever. It's actually a combination of emerging technology and old school technique.
The guys that have been doing it for many many years, say that you should always put your bondo on bare metal. They say this because the fillers of 10 years ago, were not as good as they are today in terms of adhesion. The old school fillers were primarily manufactured to obtain maximum adhesion when applied over bare metal. That's changed over time, where as the fillers today don't shrink at all, and grip really well over all kinds of surfaces, granted that it's prepped according to the makers instructions.
I myself, sand completely with a really coarse grit, nothing finer then 80. when the surface is completly prepped, no gloss from the existing surface. I go straight over that with filler. Never had any problems.
Yes, I believe that if you have ANY doubts about what's under that paint, then for gods sake, sand to metal, but if it's factory paint, or it's your previous paint and you know what's under there, do whatever you want!
Old Dec 11, 2009 | 08:40 PM
Spawne32's Avatar
YOU DO NOT SAND DOWN TO METAL TO APPLY BONDO, you did it right, you sand the area with a coarse grit, fix the area, metal glaze over your bondo, sand, and then primer the area when your satisfied with the even spots. Reference pics...
amen to what eyger said
Old Dec 11, 2009 | 08:42 PM
Spawne32's Avatar
small amounts at a time, much easier to manage
Old Dec 12, 2009 | 04:26 AM
Jenkinsal2's Avatar
Actually if you really want to get technical about all of that You should read the material technical sheets that outline application/prep techniques and follow those.
Old Dec 12, 2009 | 05:22 AM
ken9's Avatar
Look very good. As long you don't have any high or low spot.
R59
Jun 4, 2005 06:34 PM
JRSC EM1
Nov 7, 2004 10:47 PM
Hatchdude
Aug 27, 2004 11:45 AM
accorracer
Aug 12, 2002 04:46 AM
UnrealSpeed
52
Feb 13, 2002 06:52 AM
