Dent in Hood
Old Jun 30, 2008 | 01:49 AM
dth0ng69's Avatar
Default Dent in Hood
i have a 96 civic lx, okay some guys sat on my hood, and it left a whole bunch of dents, i started smashing the other side of the hood and part of it came out. But part of it is being blocked by this part
Is there a way to get that big part out? or what should i do? it seems like it would be so easy to take out if that big part wasnt there.
Modified by dth0ng69 at 2:57 AM 6/30/2008
Old Jun 30, 2008 | 02:02 PM
Disease's Avatar
Default Re: Dent in Hood (dth0ng69)
You can not remove that piece. Technically you can cause anything can be removed but that is the innerstructure of your hood. It allows your hood to crumple properly in a front end collision.
If you are hell bent on just tapping it out to make it look better you can drill a hole big enough to fit a screw driver or something in there to help push out the dent. But then your left with a hole on the underside of the hood ofcourse.
Usually what shops do is spot weld a rod onto the front side of the hood to stick a slide hammer onto and pull with that.
What they used to do was drill a 1/8th hole and use a body hood to pull the dent out but that could fail over time especially on a hood.
So there are some options for you. Good luck.
Old Jun 30, 2008 | 02:03 PM
Disease's Avatar
Default Re: Dent in Hood (Disease)
I forgot to say, make the guy buy you a new hood.
Old Jul 1, 2008 | 03:42 AM
RoadRage212's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Disease &raquo;</TD></TR><TR><TD CLASS="quote"> make the guy buy you a new hood. </TD></TR></TABLE>
After you pistol whip his ***.
Old Jul 3, 2008 | 10:40 PM
DynastyRacer22's Avatar
put dry ice on the other side of the hood or..blow dry it for about 30sec and get a air duster in a can and spray it upside down
Old Jul 6, 2008 | 06:32 AM
GuNnErGoD's Avatar
Take it to a PDR shop. They will drill a small hole in the webbing there and work the dent out from below. Depending on the size of the dent it could be up to $250.
Old Jul 6, 2008 | 02:36 PM
SneezinCD5's Avatar
Default Re: (GuNnErGoD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GuNnErGoD &raquo;</TD></TR><TR><TD CLASS="quote">Take it to a PDR shop. They will drill a small hole in the webbing there and work the dent out from below. Depending on the size of the dent it could be up to $250.</TD></TR></TABLE>
Cheaper to just get another hood if they charge that much.
Old Jul 6, 2008 | 08:18 PM
GuNnErGoD's Avatar
And have it repainted? Unless he finds one thats is in just as good condition used
Old Aug 27, 2008 | 09:27 PM
acmoc's Avatar
blow dryer 60 sec. and upside down air duster, dry ice, dent out, ding king. All of these have worked for me in the past
Old Aug 27, 2008 | 11:52 PM
dohczccrx's Avatar
Default Re: (acmoc)
just get a scraper and heat it up with a torch and then slice the little thing holding it to the hood looks like foam. then when you are done just refoam it that how i have seen paintless dent guys do it a million times
deerman2701
Nov 24, 2007 07:42 AM
ekcivic9
Jan 7, 2006 11:43 AM
89 pos
Nov 17, 2005 04:35 PM
phazeshifter
Jan 15, 2003 02:56 AM
91SIvic
Oct 18, 2002 06:38 AM
