Changing dash color
Old May 17, 2007 | 05:47 PM
Chef Andre's Avatar
HT's TOP CHEF
Default Changing dash color
I hope this is in the right section but I'm looking to change the color of my dash.
It's grey and I want to make it black. Can I just paint it? I'm sure it's been done before so does anyone have any pointers? Is there a vinly specific paint? What color matches the factory best? Will I have to use a specific clear coat? Should I just take it to an upholstrey shop? Thanks in advance
Old May 17, 2007 | 07:08 PM
Cain Marko's Avatar
Rotary Lift Specialist
Default Re: Changing dash color (Chef Andre)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chef Andre &raquo;</TD></TR><TR><TD CLASS="quote">I hope this is in the right section but I'm looking to change the color of my dash.
It's grey and I want to make it black. Can I just paint it? I'm sure it's been done before so does anyone have any pointers? Is there a vinly specific paint? What color matches the factory best? Will I have to use a specific clear coat? Should I just take it to an upholstrey shop? Thanks in advance </TD></TR></TABLE>
There is a special vinyl additive we can mix in with our paint that will allow you to paint a dash, we did so on an Impala SS that we restored. I will find out specific numbers for you tomorrow but its a dupont product. Everything will have to be scuffed with a grey scotchbrite but I have seen the results and they came out fantastic
Old May 17, 2007 | 09:40 PM
Chef Andre's Avatar
HT's TOP CHEF
Default Re: Changing dash color (Cain Marko)
^^^Thanks so much man. Painting the dash seems to be my only option because finding a black rhd dash is danm near impossible. Where are you located at?
Old May 18, 2007 | 03:26 AM
Cain Marko's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chef Andre &raquo;</TD></TR><TR><TD CLASS="quote">^^^Thanks so much man. Painting the dash seems to be my only option because finding a black rhd dash is danm near impossible. Where are you located at?</TD></TR></TABLE>
Connecticut, I will write a note to myself to get that product number for you. I am almost positive you just mix your paint like you are going to do a basecoat and then you mix in the vinyl additive. I wish I got pictures of that Impala that came in
Old May 18, 2007 | 05:16 PM
96GSRcx's Avatar
Read through this post
Old May 18, 2007 | 05:39 PM
speedworks's Avatar
Default Re: Changing dash color (96GSRcx)
find someone that sells -sems- vinyl dye. you can clean the dash really good, wipe with lacquer thinner just a few moments before spraying, and apply three thin coats to the dash. it never come off, best dye on the market.
Old May 18, 2007 | 07:15 PM
kiddcarbuff's Avatar
Default Re: Changing dash color (speedworks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedworks &raquo;</TD></TR><TR><TD CLASS="quote">find someone that sells -sems- vinyl dye. you can clean the dash really good, wipe with lacquer thinner just a few moments before spraying, and apply three thin coats to the dash. it never come off, best dye on the market. </TD></TR></TABLE>i did that to my accord, went from blue to black! its held up great everywhere BUT on the door sills, it literally wore off, so i scuffed it and dyed it again, no big deal, thats the only part i dyed that hasnt lasted, i did the dash, door panels, rear panels, speaker covers, decklid, all the plastic in the trumk, and the carpet, its held up amzingly well
Old May 18, 2007 | 09:00 PM
Chef Andre's Avatar
HT's TOP CHEF
Default Re: Changing dash color (kiddcarbuff)
Great info dude. Just wondering what's the best way to deep clean the dash? Will rubbing alcohol work or will just basic soap and water do. The reason I ask that is because I wanna make sure the paint sticks good and has a clean finish. Also what the hell is lacquer thinner and where can I buy it?
EDIT&gt;&gt;&gt;&gt;&gt;Okay I found the dye online and about to purchase it. Which color dye best matches oem honda black: landau black, satin black or gloss black
Old May 18, 2007 | 11:52 PM
QUICK13's Avatar
you can get it from o'reilys. once you scuff it, use wax and grease remover, then wipe that off, apply adheasion promoter, then dye. If you don't get the wax remover off good it will fish eye, and if ou don't scuff it and clean it with the was and grease remover the dye will not stick due to the natural oils in your hands. I did not clean my steering wheel good ad its flaking.
Heres a pic of my dash, door panels, and console they were tan.
I also used the RIT dye on my carpet, I am very pleased. Be sure to use adheasion promotor tho expecially on hard plastic. It will falke off badly. good luck
Daygo DC2
Sep 7, 2007 11:37 PM
bodiez
Aug 2, 2006 01:14 AM
94gsr18kid
Jan 27, 2005 02:47 PM
lazykiwi
15
Sep 5, 2004 05:06 PM
