body work on daily driver
Old Jan 1, 2014 | 08:57 PM
raverx3m's Avatar
Default body work on daily driver
i see guys driving with chunks of bondo hangin on their panels and a sprinkle of paint over it.
but bondo will absorb water if daily driving with it exposed.
i dont have time to do the body work all at once and paint the car right away that will take like 3-4 days.
what can i do to fix it panel by panel then do final sanding and prep right before painting..
can i use primer sealer or epoxy paint to seal the bondo for time being?
or any other spray can can seal it up temporarily for like 4-5 months or less?
the hood and fender need some decent bondo work and other panels need alot of dings fixed.
Old Jan 2, 2014 | 11:22 AM
jasoncrashtech's Avatar
Default Re: body work on daily driver
You can do it in a step by step process if you want. Just dont leave bare metal or open bodywork. Feather the paint back like normal and block your bodywork out, use a decent primer (thermal set, nothing out of a rattle can) but dont block out the primer. Leave some guide coat on it until your ready for base and clear.
Old Jan 2, 2014 | 07:20 PM
SIRX's Avatar
depending how much decent is to you I would suggest buying replacement for both of those. it will be cheaper in the long run
Old Jan 3, 2014 | 04:29 PM
Hidenplanvew's Avatar
Epoxy is non porous, just spray or roll it on and let it fully cure. But any primer put on to seal, will need to be sanded 80-90% back off and re primed as primer has no UV protection.
Old Jan 3, 2014 | 04:47 PM
schollianmj's Avatar
I replaced both the front fenders on my car with new parts off Ebay for 120 total. I dont think that is a bad price to know that I dont have any Bondo that I probably would have screwed up and had to redo a few times.
Old Jan 3, 2014 | 06:05 PM
raverx3m's Avatar
they are not bad to replace and they have original vin tag matching to the car im trying to keep them
waynesumner
Paint and Body
Jun 14, 2013 10:45 AM
Vagitarian
Paint and Body
16
May 24, 2012 02:33 AM
raverx3m
Paint and Body
Jun 3, 2011 11:13 AM
UnoPuntoCinco
Paint and Body
May 31, 2007 04:20 AM
NuRon
Paint and Body
10
Apr 23, 2007 03:06 PM
