bent corner
Old Jan 4, 2009 | 08:00 PM
supermeister's Avatar
Default bent corner
ok, when i recieved my new hood (old one was crashed) the corner was bent down in the mail and in a rush to put it on i just straitened it up with a pair of plyers before sending it to a body shop to get the radiator support straitened out. I only realized the great mistake i made afterwards. what should i do to fix this?? pics are below
Old Jan 4, 2009 | 08:06 PM
slimgsr's Avatar
Default Re: bent corner
It's really not that bad. I'd pull the hood off, grab a toe dolly, and hammer that back into shape. You're going to need a little glaze to finish it off before primer, but it shouldn't bother anything down the road. I did a similar thing a door corner. Good luck!
Slim
Old Jan 5, 2009 | 04:22 PM
thanks! now, i dont know anything about painting so how exactly would i go about repainting it? I should do the whole hood (just black, too cheap to color match it to the car) because its just the paint that it came in the mail with and apparently that rusts over time. I might just go 50 dollar paintjob style, except just on the hood.
Old Jan 5, 2009 | 07:10 PM
slimgsr's Avatar
Well..... I'll assume you don't have paint guns or even an air compressor to support a paint gun so I'll try a way that's most inexpensive (although not the most durable). After you get the panel straight with glaze (which should be all you need if you did the metal work even semi-properly), prime the spot (~3 coats) with some spray can primer (we're going with cheap, remember?), sand with 180, re-prime, then sand with 400grit along with the rest of the hood. I know, that was the longest sentence ever. Anyways, now the surface is prepped for any paint you'd like to put down. Good luck again.
Slim
OrellanaEK9
Paint and Body
Jan 17, 2012 05:31 AM
The_Head
Paint and Body
Sep 23, 2009 07:30 AM
98slvrcx
Aug 7, 2002 10:23 PM
