Applying seam sealer
Old Apr 12, 2011 | 10:12 AM
siblues's Avatar
Default Applying seam sealer
I was just wondering how everyone goes about applying seam sealer?I am in the process of removing the oem stuff and the wire brush I am using is taking it down to bare metal so I figured I would ask and see if you guys apply it to bare metal or prime and apply?Any tips would be greatly appreciated.
Old Apr 12, 2011 | 04:35 PM
gorillafart's Avatar
Default Re: Applying seam sealer
read the directions
Old Apr 12, 2011 | 06:43 PM
siblues's Avatar
Believe me I can read I am just asking what everyone that has been painting for years with tons of experience do?Thanks for the useless response.I dont mean to be rude in here I just dont understand why people are so reluctant to help on here anymore.
Old Apr 12, 2011 | 08:27 PM
because people post threads asking the same questions time and time and time and time again
people are too lazy to search
but to answer your question, some seam sealers/adhesives come with their own "primers" you lay down on BARE metal be4 you apply the seam sealer product.. if you have epoxy primer down, lay it on top of that. one rule of thumb to live by when painting at any stage is, its only as strong as what you put it on
Old Apr 12, 2011 | 09:06 PM
siblues's Avatar
Thank you for that reply.I do my fair share of searching but sometimes you get the same answers from the same people.I try to ask in the proper forums for the correct info.Thanks again and if anyone else can chime in please do so.
Old Apr 16, 2011 | 08:14 AM
SQ is the SQUAD's Avatar
well i was searching for some answers, i found 10 threads where some jerk said to search. no one really helped. if as many people answered the question instead of saying search there would actually be less threads made. whenever i search for a topic i am almost guaranteed to find a thread where someone else asked for an answer and was told to search. makes me not even want to search.
Old Apr 18, 2011 | 12:56 AM
siblues's Avatar
I agree and I understand alot of things get asked to death around here because people refuse to search or are too lazy to do so but I try to do my best to keep that to a minimum.I am just trying to get some feedback about what the experienced guys on here liketo do?
Old Apr 18, 2011 | 03:51 AM
i was looking for some infor on using the 3m stuff to apply a new roof skin. on ourtube the use this applicator gun, but the gun is like $50. i dont want to buy the gun seeing ill prob onl use it once. if i squeeze the two parts out on a mixing board and apply it b brush, will it leave enough curing time for me to apply,set and clamp down my new roof skin?
Old Apr 18, 2011 | 06:58 AM
jasoncrashtech's Avatar
what knid of seam sealer are you using ? brushable seam seal? or a two part that you need a seam seal gun for?
Old Apr 18, 2011 | 02:40 PM
they should have different seam sealers, that cure at different times. so you can get a slow, medium and fast curing seam sealer. slow of course gives u time to move the panel around and adjust... fast of course being, set it, and leave it.
Old Apr 18, 2011 | 03:26 PM
if your going to use metal bond for your roof skin, you really shouldn't mix the bond on a mixing board. the whole process revolves around the mixing tip. if it doesn't mix properly, it doesn't cure and that could make a big problem.
im sorry dude its a pricey ordeal but its the truth.
most products even require a tube length purge so the mix is complete before you apply it on a panel
every thing i just said is basic rule of thumb for any two part seam sealer or two part bonding product.
Old Apr 18, 2011 | 05:16 PM
i was planning on using 3M PANEL BONDING ADHESIVE 2-PART CARTRIDGE 08115
Old Apr 18, 2011 | 05:33 PM
shouldnt you be spot welding your roof skin back on? not using panel bonding adhesive?
Old Apr 18, 2011 | 06:54 PM
it was put in with a combination of both from the factory
Old Apr 18, 2011 | 08:11 PM
some oem manufacturers insist on weld through metal bond. you bond the roof skin and spot weld the four corners. toyota mainly. from oem manufacturer's to i-car classes using bond only is an approved repair
using a used roof skin is a different story if your drill the spot welds out
Old Apr 18, 2011 | 11:00 PM
i can agree with this.
Old Apr 19, 2011 | 04:16 AM
siblues's Avatar
Well I can get my hands on the seam sealer gun or use the brush on.I am just respraying the entire car inside and out and wanted to really clean up the sealer in the bay.The car has had a full wire tuck done with a Rywire harness so I am trying to have the bay look very clean.I am not removing too many bolt holes I am not into the whole shaved trend.I just need the sealer to look very smooth around the shock towers.
Old Apr 19, 2011 | 10:51 AM
Siblues, 3M has some tips that you can put onto your seam sealer tubes... that will help lay the seam sealer as smooth or flat as possible. or use a plastic spreader, and cut it to shape so it can help spread the seam sealer evenly
Old Apr 19, 2011 | 12:04 PM
so what should i fo if i cant get the gun. how would i get the two parts to come out the tube and mix evenly
Old Apr 19, 2011 | 01:10 PM
you'll make life harder on yourself trying to figure a way to dispense them tubes without a gun. just get the gun. borrow it or something... buy it, use it, return it lol.
its very important that they catalyze properly. especially with the mixing nozzles that are used, you have to be able to dispense both parts of the cartridge evenly.
Old Nov 30, 2013 | 10:32 AM
teamfastbreak7's Avatar
Which brand of paint do you guys use after applying the seam...because I use rustoleum and now my seam sealer is tacky to the touch and it catching on dust..Its been in my car for over a year now and still feels a little bit tacky..any idea what paint I should use
Fastjato33
Feb 23, 2009 04:23 PM
thinknology
Honda Civic (2001 - 2005)
29
Aug 2, 2007 03:52 AM
highcomp
Jan 31, 2004 02:47 PM
genop
Feb 7, 2003 10:25 PM
CW_97_ITR
Nov 20, 2001 05:53 AM
