2003 Honda Pilot, code P1491, need to clean EGR ports
Does anyone know where to get instructions for cleaning the EGR ports on my 2003 honda pilot.
I have a 1997 Accord and found great instructions at https://honda-tech.com/zerothread/1664547
Under:
EGR Port Cleaning for 90-97 Accords and
94-97 Accord EGR Port Cleaning
I am sure that my error code fits under:
TSB #012704 -- REQUEST FOR VISIT. CUSTOMER COMPLAINT OF THE ENGINE STUMBLING, SHUDDERING, HESITATING, OR MOMENTARILY SURGING. MAY ALSO EXPERIENCE A CHECK ENGINE LIGHT, AND DIAGNOSTIC TROUBLE CODE (DTC) P1491 MAY BE DISPLAYED. *TT (NHTSA ID #10005652, JANUARY 27 2004)
and
TSB #00009 -- WARRANTY EXTENSION: EGR VALVE CONTAMINATION OR EGR POR CLOGGING MAY CAUSE DTC P0401, DTC P1491, OR ENGINE HESITATION/SURGE. *TT (NHTSA ID #10017431, JULY 20 2005)
I would however like to fix it myself if I could. I do not live close to a dealer.
Any help would be greatly appreciated
Thanks
Under:
and
Thanks
Re: 2003 Honda Pilot, code P1491, need to clean EGR ports (wormsmith)
The repair is under s/b 05-026. It is covered under the Emissions extension for 8 years 80,000 miles under certain vin ranges. If you want to do this repair yourself,just replace the EGR valve and gasket. No cleaning is required. The repair is just for a sticking valve and not a cloged port like in the S/B you listed. A kit form the dealership will run you under $100.00. Good luck
Planning on changing out my EGR valve on my 03 Pilot and wanted to know where exactly to look for the valve. Any pictures out there? Thanks
http://slhondaparts.com/browse.asp?M...ViewParts=true
Its located to the right of the front cylinder head, its #1 in the above link.
The links to pics of the location of the EGR valve in this thread don't work, so I posted pics of the one in my Pilot when I replaced it this afternoon - BTW, easiest repair job ever, but it did take a while to find the darn thing.
http://www.flickr.com/photos/59226525@N03/5423794440/
http://www.flickr.com/photos/59226525@N03/5423794314/
I would recommend cleaning the ports also. There's probably a ton of crap in there that clogged the EGR valve to begin with. Only takes about an hour to clean or less. Peace of mind.
JeffWashington
12-12-2016 10:34 AM
swertepinoy
10-06-2009 06:40 AM
brothers
10-28-2004 11:10 PM
