Northwest Alaska, Idaho, Montana, Oregon, Washington, Wyoming
Tracition... Help
Old Apr 3, 2008 | 12:21 PM
ArchEnemy's Avatar
Default Tracition... Help
Posted in the suspension forum with no responses... maybe some NW Brothers and Sisters can help me out.
https://honda-tech.com/zerothread?id=2267009
Old Apr 3, 2008 | 12:25 PM
ArchEnemy's Avatar
Default Re: Tracition... Help (ArchEnemy)
ya i know i spelled traction wrong...
Old Apr 3, 2008 | 06:07 PM
0554's Avatar
did you get your car aligned after modifying your suspension?
Old Apr 4, 2008 | 07:35 AM
ArchEnemy's Avatar
Default Re: Tracition... Help (0554)
Sure did.
Old Apr 4, 2008 | 11:30 AM
NA425DragSter's Avatar
* B A N N E D *
your off brand springs .... get something with a higher spring rate, and also wat kinda tires are you running
Old Apr 4, 2008 | 01:01 PM
ArchEnemy's Avatar
Default Re: (NA425DragSter)
toyo
Old Apr 4, 2008 | 01:02 PM
ArchEnemy's Avatar
Default Re: (ArchEnemy)
ive used the springs before... same identical setup on a DA never had issues...
Old Apr 4, 2008 | 01:12 PM
* B A N N E D *
yea and da also have factory traction bars. some what like the aftermarket ones eg-dc-ek dosn't
Old Apr 4, 2008 | 01:44 PM
ArchEnemy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NA425DragSter &raquo;</TD></TR><TR><TD CLASS="quote">yea and da also have factory traction bars. some what like the aftermarket ones eg-dc-ek dosn't</TD></TR></TABLE>
Wow.. i didnt know that. You think that could be the issue or at least part of it? The shocks and springs are only temporary, but i think it would be safe to assume that without traction bars i would still have similar issues even if i had a better suspension setup correct?
Sorry but my suspension knowledge is limited...
Old Apr 5, 2008 | 12:43 AM
Numba1 K Series's Avatar
Hi!
Play Gran Turismo.
Old Apr 5, 2008 | 10:22 AM
ArchEnemy's Avatar
Default Re: Tracition... Help (Numba1 B Series)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Numba1 B Series &raquo;</TD></TR><TR><TD CLASS="quote">Play Gran Turismo. </TD></TR></TABLE>
i have, but what does that get me?
Old Apr 5, 2008 | 06:14 PM
ArchEnemy's Avatar
Bump...
Old Apr 6, 2008 | 09:34 AM
Hi!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ArchEnemy &raquo;</TD></TR><TR><TD CLASS="quote">
i have, but what does that get me?</TD></TR></TABLE>
Traction for your car.
Old Apr 6, 2008 | 11:17 AM
JayK's Avatar
What setting are your shocks at? What are the spring rates of the springs?
Old Apr 6, 2008 | 04:47 PM
ArchEnemy's Avatar
Default Re: (JayK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JayK &raquo;</TD></TR><TR><TD CLASS="quote">What setting are your shocks at? What are the spring rates of the springs?</TD></TR></TABLE>
shocks have been adjusted bit by bit over the last week to see if it makes a difference... and havent noticed a change in what im talking about... The rate are 450 in the front and 281 in the rear. i think thats 8kg and 5kg... not sure.
Modified by ArchEnemy at 7:30 PM 4/6/2008
Old Apr 6, 2008 | 06:27 PM
ArchEnemy's Avatar
so i threw the kyb shocks that were on the car before, and still have the same issue...
Traction for your car.</TD></TR></TABLE>
thanks for being a douche
Modified by ArchEnemy at 7:36 PM 4/6/2008
Old Apr 6, 2008 | 09:51 PM
ArchEnemy's Avatar
goodnight bump
Old Apr 7, 2008 | 05:57 AM
abawp's Avatar
The rate are 450 in the front and 281 in the rear. i think thats 8kg and 5kg... not sure.</TD></TR></TABLE>
Holy jeebus those are stiff. Keep in mind that you lose droop travel of your suspension the stiffer the springs get. In your situation, it sounds like you are "catching air" over some of these rough bumps, resulting in you losing traction.
What kind of no-name springs are these? They sound suspiciously like coilover sleeves...
Modified by abawp at 7:04 AM 4/7/2008
Old Apr 7, 2008 | 08:55 AM
ArchEnemy's Avatar
Default Re: (abawp)
i dont remember the name, when i bought the car it had cut springs so i just bought some cheap ones to throw on temporarily... ill just deal with it deal i purchase a better deal. Thanks
Old Apr 7, 2008 | 10:04 AM
abawp's Avatar
FYI, these are what I was talking about:
If you have something like this, you can install "helper" springs, which are really REALLY soft coil springs. These softer springs are typically installed in most name brand coilover kits (H&R for example) and provide proper droop travel when the suspension is unloaded.
If you don't have these, but rather a standard lowering spring, try going with ones that are progressive rather than linear (neuspeed makes progressive rate springs FYI). These get significantly stiffer the more they are loaded up, so initially they can be soft enough to provide adequate droop travel.
Old Apr 7, 2008 | 08:09 PM
ArchEnemy's Avatar
Default Re: (abawp)
thats exactly what i have... thanks for the info!
Old Apr 8, 2008 | 07:43 AM
abawp's Avatar
Just make sure you get an isolator to go between the "helper" spring and the main spring. Usually made out of rubber, the high amount of friction will keep the parts firmly in place with no risk of slippage
AK77
Jul 20, 2006 10:59 AM
92b16si
Suspension & Brakes
10
Apr 27, 2006 04:01 PM
idriveadelsol7
Apr 24, 2005 09:53 PM
tweekerz
Mar 25, 2005 10:01 AM
silverslicks
Feb 3, 2005 07:24 AM
