Northwest Alaska, Idaho, Montana, Oregon, Washington, Wyoming
Need help w/passing emissions
Old Mar 28, 2010 | 03:15 PM
easyFOsheezy's Avatar
Default Need help w/passing emissions
I recently failed an emission test in WA state, and was seeing if anybody knew how to bypass the test w/o swapping out the whole exhaust system. I'm currently running aftermarket headers with a carsound cat, and fujitusbo catback on an 01 type R. The Fault Code is P0420 Catalyst System Efficiency Below Threshold Bank 1. If anybody has any information that would be greatly appreciated. I would prefer avoiding the hassle of swapping my stock exhaust back in. Thanks so much!
Old Mar 28, 2010 | 03:35 PM
Ruben19's Avatar
Default Re: Need help w/passing emissions
dude!
you don't need to swap your stock exhaust.
i passed emissions without a catalytic converter.
this is what i used so my engine light dont come on.
http://i210.photobucket.com/albums/b...21/TXS004c.jpg
they sell it at schucks or any other autoparts.
I also have this
http://www.o2simulator.com/images/la...sal_full_D.jpg
works perfect. but not sure if i can pass emissions with it yet. i'll find out later when i take my car to emissions.
Old Mar 28, 2010 | 05:06 PM
jdm_ekcivic's Avatar
Or register out in the sticks. Granite Falls works.
Old Mar 28, 2010 | 09:03 PM
4DrSleepyHead's Avatar
luckily my mom has connections so i dun need to go do emissions lol
Old Mar 29, 2010 | 04:47 PM
Are you being serious about passing emissions in Granite Falls or u messing w/me? Anyway, if anybody has a hookup or could help me pass emissions, I'll pay you. And get you lunch too if u want. Please PM me if you can help. Thanks!!
Old Mar 29, 2010 | 05:28 PM
JaysHatcH's Avatar
get a PO box in granite falls or mount vernon or somewhere, than register it to that address.
Old Mar 29, 2010 | 05:50 PM
Totally serious. Got a family friend that lives out there and used his address.
Old Mar 30, 2010 | 11:07 AM
Evs-One's Avatar
Solbros Owns Me
Or, replace the catalytic converter with one that actually works, and you won't have the P0420 code.
The key is getting the secondary O2 to send good info to the ECM...spark plug anti fouler trick is your best bet. Pulls the sensor out of exhaust stream enough to send a good reading.
Old Mar 30, 2010 | 11:12 AM
I don't understand. If I failed emissions in Bellevue, why would I pass in Granite Falls? And also, why would I need a different address? Is it required by the emissions? And lastly, would I still pass if I failed once already and brought in my form that said I failed? I apologize for being so clueless. New to all of this. But I appreciate all the info!! Thanks.
Old Mar 30, 2010 | 03:31 PM
Ruben19's Avatar
some areas don't require emissions so that's why they telling you to register the car there.
no need 2 do this. all you gotta do is to get rid of the engine light and then u good 2 go.
the way i do it works pretty good.
i have a built GSR with high compression pistions, cams and more shiiitttt and i still pass emissions. all i do is Swap my test pipe for my catalytic convertor, put my obd2 ecu back. that's it. car idles pretty bad but still pass.
Old Apr 5, 2010 | 06:27 PM
Ruben19's Avatar
problem solved.
passed emissions thanks to me
easyFOsheezy
Mar 28, 2010 03:16 PM
singlecammajamma
Oct 4, 2005 09:47 PM
ruiner17
25
Jun 29, 2004 10:19 AM
ridnmyhonda
Jan 26, 2003 08:09 PM
Ef Whore
Nov 24, 2002 01:23 PM
