EXOSPEED 3 PIECE FRONT ENDS!!
Old Aug 5, 2011 | 12:26 PM
ChrisMillerRacing's Avatar
Default EXOSPEED 3 PIECE FRONT ENDS!!
Exospeed Racing Designs: 3 Piece Racing Front End
Available for: 92-95 Civic Coupe and Hatchback / EK 99-00 Civic Coupe/HB / 99-00 Integra / 88-91 CRX
We’re excited to offer the Exospeed Racing Designs 3 piece front end for the 92-95 Civic Coupe/HB, 99-00 Civic Coupe/HB and 98-00 Integra. We run this on Chris Miller's own EG!! It’s made out of a durable, high quality, thick fiberglass material. The 3 piece front end consists of a front bumper that has been redesigned and extended about 1.5” to clear 4.5” thick intercoolers. The front opening shroud can also be trimmed to fit depending on how thick and how far you have your intercooler extended forward.
The fenders extend to clear 24.5”, 25”, and 26” tall drag racing slicks. The fenders are designed to clear 9” wide tires on the common 13x7.5, 13x8, or 15x8 wide wheels with 5” backspace. 26” tall slicks will also clear depending on the wheel backspace and width. Extreme rim width and backspace such as 15x10 with 4” backspace may have clearance issues, but the fenders can be modified on the lip to help clear wider tire/wheel setups.
Another feature we have on the fenders is the smooth transition to the OEM sideskirts. A recessed area allows the OEM side moldings to be mounted to match the existing OEM side moldings on the door and rear quarter panel.
An optional front lip will also be available in a few weeks. This allows certain cars who have the front raised up to fill in the front to reduce the ground to bumper gap.
88-91 CRX: $745
92-95 Civic Coupe/Hatchback: $745.00
99-00 Civic Coupe/Hatchback: $745.00
98-00 Integra: $785.00
CRX
EG OPEN
EG CLOSED
99-00 COUPE/HATCH OPEN
98-00 INTEGRA CLOSED
98-00 INTEGRA OPEN
1. How will this mount compared to the stock bumpers and fenders?
The fenders still retain the stock tab locations which you have to drill before putting on the kit. The fender will bolt down with the OEM 10mm bolts.
The front bumper also retains the stock tab locations on the top where it bolts on the radiator support. You will also need to drill holes where the fender and bumper meet. We recommend a washer, bolt and wingnut to keep them together and in place. This also makes it easy to unbolt and take off the bumper.
2. What is the weight of the 3 piece kit?
The EG Bumper is about 14.2lbs. The EG Fenders are about 3.6lbs.
3. Will a carbon fiber version be available?
Carbon Fiber is available as a custom order. We will need FULL payment and takes 2-3 weeks to manufacture. Price is $1550.00
4. How is the kit shipped? UPS? FedEx?
Due to the size of the box we ship it in, it has to be shipped by Freight. We work with several freight companies and will get you the best price possible.
We can also ship internationally.
5. What tire size will it clear?
The kit was fitted with 24.5x9x13 MT, 25x8.7x13, 26x8.5x13 and 26x9x15 tires. They fit under the fenders. These were using 8” wide rims with 5” backspace. The only time that there maybe a clearance issue is if you’re using a 10” wide rim with a low backspace. A 4” backspace will stick out the fender for sure. 5” backspace on a 10” wide rim, will require trimming of the inside fender lip. Any aggressive/extreme rim backspace setup may not be able to “dump” the car lower.
Shipping: By Freight, $220-280.00 (48 states) Canada shipping available
($320-$380)
For an extra $100, we can order the kit in WIDE form, and you can fit 15x11's!! Ask me for more details
Old Aug 9, 2011 | 06:33 AM
Default Re: EXOSPEED 3 PIECE FRONT ENDS!!
bump up guys!!!!!!!!!
Old Aug 11, 2011 | 07:41 AM
bump up to the top!!
Old Aug 11, 2011 | 10:14 AM
Old Aug 12, 2011 | 06:43 AM
to the top guys!!
Old Aug 18, 2011 | 06:54 AM
bump up to the top
Old Aug 19, 2011 | 07:21 AM
bump up to the top
Old Aug 22, 2011 | 08:25 AM
bump up to the top
Old Aug 23, 2011 | 07:35 AM
Please call 631 465 0988 or e-mail us at Sales@GetPowerhouse.com to order!!
Old Aug 24, 2011 | 07:57 AM
Old Aug 24, 2011 | 10:44 AM
Old Aug 25, 2011 | 11:17 AM
Old Aug 26, 2011 | 07:18 AM
Old Aug 29, 2011 | 09:53 AM
Old Aug 29, 2011 | 01:55 PM
SIKNASTREXO's Avatar
bumper...whers the pic of the rex front end,,,
Old Aug 30, 2011 | 08:04 AM
crx added!!!
Old Aug 31, 2011 | 10:58 AM
bump up to the top
Old Sep 1, 2011 | 05:44 AM
September 1st here, hope everyone had a great summer@!
http://www.getpowerhouse.com
Old Sep 1, 2011 | 01:33 PM
to the top!!!
Old Sep 2, 2011 | 06:21 AM
bump to the top
Old Sep 7, 2011 | 07:26 AM
Old Sep 8, 2011 | 09:57 AM
Old Sep 10, 2011 | 09:59 AM
ChrisMillerRacing
12
Apr 11, 2014 05:43 AM
ChrisMillerRacing
157
Mar 19, 2013 10:05 AM
ExospeedAMcrx
243
Jan 17, 2011 07:48 AM
Bigmojoj27
Oct 19, 2006 01:57 PM
