E-BRAKE LOCK KIT!!
Old Jan 10, 2008 | 11:09 AM
alscrx's Avatar
Default E-BRAKE LOCK KIT!!
The concept is that the E-Brake cannot be released down until the lock is removed. Its another theft deterrent for thieves to try to get them to move on and if the car is driven or towed with lock in place it will make too big of a scene causing someone to see something. After all, when tires screech everyone looks outside!
It can be installed quickly and be kept in your glove box or your girl’s purse. It’s small and is only 6.3 ounces in weight including lock and shaft! It will come in either gloss black or brushed stainless steel and includes 2 keys.
Lets clear some things up. The console in no way plays a role in the E-Brake lock. The e-brake arm is a double layer of metal. Inside that double layer is a steel half moon shaped piece with teeth in the edge for the e-brake lever to catch on.
What this lock is doing is going through your handle housing on one side, going through the half moon piece of steel, and out the other end of the handle housing. THIS SHAFT IS PASSING THROUGH 2 DIFFERENT PIECES OF METAL which is why you can not release the e-brake with this shaft in place! You e-brake arm can not slide down and over the moon shaped piece of steel if there is something slid through both pieces! The weight is placed on the e-brake housing itself which is steel and bolted in 2 places to your floor NOT THE CONSOLE.
If you have a deadbolt on your house door then you can see the concept.
There is a housing that holds a pin inside and a latch on your door, then on your wall you have a latch. When you close the door the 2 latches mate and when you twist the **** the pin slides through them preventing you from opening the door no matter what you do unless you remove the pin which is holding the 2 latches together.......hope you understand now
__________________
Modified by alscrx at 11:56 AM 1/11/2008
Modified by alscrx at 8:22 PM 1/11/2008
Old Jan 11, 2008 | 07:57 AM
alscrx's Avatar
Default Re: E-BRAKE LOCK KIT!! (alscrx)
Taking order at $80 each unless there is a group buy of 10 or more at $70 each shipped
Modified by alscrx at 6:40 PM 9/7/2008
Old Jan 11, 2008 | 08:05 AM
SpeedoKing's Avatar
will this work if you have a arm rest?
Old Jan 11, 2008 | 01:06 PM
alscrx's Avatar
Default Re: E-BRAKE LOCK KIT!! (SpeedoKing)
Yes it will, You just need to install it before the armrest
Old Jan 11, 2008 | 05:41 PM
spoolinfool's Avatar
45 bucks Please go to masterlock .com and you will find the exact product for like 7 bucks with no middle man.
Old Jan 11, 2008 | 05:57 PM
.:Made in OC:.'s Avatar
Default Re: E-BRAKE LOCK KIT!! (spoolinfool)
It looks like it can be cut with a fence cutter, am i wrong? The metal seems small and easy to put a cutter around and snap right through...
Old Jan 13, 2008 | 09:29 AM
FatRacer's Avatar
Man anyone can take that off you can even take off the center console or break it so you can release the E-brake.
Old Jan 13, 2008 | 01:10 PM
postman's Avatar
Default Re: (FatRacer)
hell i have a set of sidecutters that will go through that
Old Jan 13, 2008 | 05:51 PM
mormonboy's Avatar
Default Re: (postman)
lolz. this has to be a joke. haha
Old Jan 13, 2008 | 07:55 PM
REAL TIME's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by postman &raquo;</TD></TR><TR><TD CLASS="quote">hell i have a set of sidecutters that will go through that</TD></TR></TABLE>
is a theft deterrent just like club, alarms, kill switches etc. I don't know this guy and I am just reminding you folks what its purpose. Price might be a little too high for something low quality.
Old Jan 14, 2008 | 04:54 AM
alscrx's Avatar
Default Re: E-BRAKE LOCK KIT!! (REAL TIME)
Here is another protype i have been working on....Any thoughts on this one?
It actually locks the stick against the E-brake
Old Jan 14, 2008 | 10:53 AM
REAL TIME's Avatar
that would not work because you can always pull your shift **** off.
Old Jan 15, 2008 | 06:26 AM
alscrx's Avatar
Well i am using that to make a prototype for the EF's would make something to prevent that
Old Jan 15, 2008 | 09:30 AM
simply's Avatar
Yea it looks like it will be easy to break and get around it.
Although to a thief so is the club, alarms, boots, kill switches, etc....
Its all about adding more and more **** to either make them think twice, or give you a few extra seconds to catch the *****.
Price is steep, but to trying to deter thieves.
Old Jan 15, 2008 | 02:57 PM
93civicsedan's Avatar
Dude good idea but, rather than trying to hit us over the head with these prices why didnt you just due a DIY and suggest we use the masterlock coupler latch lock? Its clear in the pics that its the one you are using and it only costs about $15 retail.
Old Jan 15, 2008 | 03:10 PM
FuNkDrSpOt's Avatar
Default Re: E-BRAKE LOCK KIT!! (93civicsedan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93civicsedan &raquo;</TD></TR><TR><TD CLASS="quote">Dude good idea but, rather than trying to hit us over the head with these prices why didnt you just due a DIY and suggest we use the masterlock coupler latch lock? Its clear in the pics that its the one you are using and it only costs about $15 retail.</TD></TR></TABLE>
Because he's trying to make a profit and it's not like he's stitching Mugen on it and selling it for $400.
If you don't like his prices that's fine but quit hatin on the man, damn.
Old Jan 15, 2008 | 07:12 PM
alscrx's Avatar
Default Re: E-BRAKE LOCK KIT!! (FuNkDrSpOt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FuNkDrSpOt &raquo;</TD></TR><TR><TD CLASS="quote">
If you don't like his prices that's fine but quit hatin on the man, damn. </TD></TR></TABLE>
Thanks but i was actually welding a bracket for it to be floor mounted and that was included in the kit for that price for the ef's only!
Old Jan 15, 2008 | 07:14 PM
alscrx's Avatar
I just got these in also... and installed it on my crx!
What do you guys think of this??
Pm me!
Old Jan 16, 2008 | 05:35 AM
alscrx's Avatar
bump to check this out
Old Jan 16, 2008 | 08:37 AM
nautica_t's Avatar
you're a douche.
this guy IM me and and wants to trade for my OEM power windows, so his offer is $350 installed or $200 I install myself or straight trade for my OEM power windows. When you can go to the hardware store and by this product.
This product is 7.95 on Masterlock.com here's the link for it the item, its all the way at the bottom of the page.
Product Number: 2847DATSC
Description: Stainless Steel, Adjustable Coupler Latch Lock
List Price (each): $7.75
^taken from the website.
http://www.masterlock.com/cgi-...e=app
last lock at the bottom of the page.
a portion of the IM he sent me.
(11:33 PM 1/15/2008) nautica_t: i'm interested in parts, but not looking but can be entertained.
(11:34 PM 1/15/2008) nautica_t: at for most is that i don't have an EF anymore, i have an iTR.
(11:34 PM 1/15/2008) nautica_t: so if you have parts for ITR, than I can definitely be entertained.
(12:25 AM 1/16/2008) alscrx: no man sorry
(12:27 AM 1/16/2008) alscrx: well if you decide your interested in the shift lock,
I sell it for $350 installed
I can send you lock and you install for $200 or an even trade. Let me know
(12:27 AM 1/16/2008) alscrx: thanks
(12:30 AM 1/16/2008) nautica_t: thank you anyways, R is tracked, so i have no need for security for it.
(12:37 AM 1/16/2008) alscrx: ok....thats only good if you notice its gone.
Old Jan 16, 2008 | 09:18 AM
alscrx's Avatar
Default Re: E-BRAKE LOCK KIT!! (nautica_t)
The im says SHIFT LOCK!!!
LOL,,,,not the ebrake lock!!!
The shift lock is worth every penny no customer complaints yet!!
fifty9singlecab
Honda Civic (2001 - 2005)
Apr 20, 2012 07:47 PM
LukieLuc
Mar 25, 2007 07:59 AM
snaileg
Nov 23, 2006 06:08 PM
wheelmanbg
18
Apr 9, 2006 07:34 PM
