Winter Cleaning...Getting ready for SPRING!
Old Feb 5, 2010 | 10:24 AM
drumritter258's Avatar
Default Winter Cleaning...Getting ready for SPRING!
Im looking to sell/trade this stuff because Im tired of looking at it and need to get more parts for my build. Prices are listed beside each item, I will entertain reasonable offers however lowballing will be refused. *If you have any questions pm me.
I am looking for the following items:
550cc or bigger injectors
Eg hatch carbon fiber *hood (oem style)
Nice set of cams for a GSR
Front aftermarket EG swaybar
5 bolt downpipe
EG intercooler piping
B18c1 head with jdm b16a cams. The head itself is pretty clean and comes with all of the sensors. Just needs valve springs, retainers, cam plates and a few of the bolts. $150obo
Dropzone strut/coilover suspension that came off a 93 hatch. Rode pretty good, but too rough for my taste. Gave my hatch a real nice stance. The front springs have some surface rust, but doesn't effect the ride. Strut tops also have red energy bushings. $100
CNC racing seats. Need a good cleaning and the passanger side bolster is torn but doesn't affect anything. Doesn't come with brackets, but will come with a brand new set of sliders. They are dirty right now from winter, but will clean up!! $150obo
MK3 Jetta front lip. Direct sway for EF/ED/CRX front bumpers and its in pretty good shape.
[/URL]
BNIB B18c1 valve stem seals. No use for them anymore so maybe someone else does? $10
Vortech 12:1 FMU that’s anodized blue and in perfect shape. Got it brand new from a friend and never used it. $50
(2x) Clock block off plate from an EG dash. $5 a piece
Energy suspension mount inserts. P/n 16.1110g. For a Acura RSX 2001-2004 Base and Type S. They are brand new. $20
[IMG]http://i72.photobucket.com/albums/i164/drumritter258/Parts%20for%20
Old Feb 5, 2010 | 11:20 AM
mzurbano's Avatar
Default Re: Winter Cleaning...Getting ready for SPRING!
pm me pics of exhaust
Old Feb 6, 2010 | 10:49 AM
AEM V2 intake for a 99-00 Civic SI, but may possibly fit other Civic/Integras. $150
Ek taillights in good shape. $50
"VTEC BAR" Bolts onto the steering rack frame, came off an integra gsr but will bolt up to a EG subframe perfectly. $30
B series plug cover. Its a stock cover that was painted black. $10
Mitsu GST turbo intake pipe with MAF and filter. Got it from a turbo kit I bought and have no use for it. Make offer
Diy boost controller. In good shape and works good. $20
d16y7/8 aem fuel rail with fpr. In good shape and anodized red. $65
D series Holley airmass header. Bottom section has some rust on it and will need to be welded up where the two pipes come together at the bottom. $40 obo
Picture of the part of the bottom that needs welded.
Old Feb 6, 2010 | 11:15 AM
hrs-parker's Avatar
bump for adam
Old Feb 7, 2010 | 12:25 PM
EG hatch exhaust. In pretty good shape and sounds amazing its just dirty. Muffler was painted black by previous owner and it would either need another coat or just stripped off. Also will need a header flange welded on and a muffler hanger welded on if it bothers you. Its 2 1/4 from the cat to axle back area then reduces to 2 1/2. $125
ATE civic slotted brake rotors. In good shape with no grooves or edges. $50
Akebono ceramic brake pads. Still have alot of life left on them. $40
D16z6 head with complete intake manifold. Everything looks to be in good shape just needs a quick hottank. Planned to throw it on a y7 block, but changed mind. Comes with everything pictured. $150obo
Autometer liquid filled boost gauge. In good shape, I just didn’t use it because it was bigger than my gauge pod. $15
Delsol Si calipers with bolts. Previous owner upgraded to gsr brakes and I have no use for them. $40
Civic hatch wiper delete plug. I had this laying in my parts bin and have no use for it. $10
Oem Civic/Integra radiator fan. Works good, just upgraded to a slim fan. $10
D series header. In good shape and no dents on the bottom runners. Will need a collector flange welded on. $Make an offer
D15b7 intake manifold. Pretty bare, but in good shape. $Make offer
1. B18c1 throttle body comes with everything pictured $30
2. B18c1 throttle body. Missing FITV, might have a spare laying around for it. Also has map sensor. $30
3. B16a throttle body. Tps is bad on it, but the screws are already out so itll be an easy swap. Also the pressed in nipple for the charcoal canister is gone (not a big deal if you deleted your canister) $20
4. D16z6 throttle body. Missing FITV, but everything in good shape. $15
5. B18c1 throttle cable. $10
Old Feb 7, 2010 | 01:26 PM
rayvo's Avatar
pm picture of both dseries header
Old Feb 11, 2010 | 10:14 AM
ill grab them for you tonight. Exhaust is off so pics should be out soon.
bump it up.
Old Feb 11, 2010 | 10:37 AM
Fibercation's Avatar
lojack?
Old Feb 13, 2010 | 12:55 AM
yea it came off a previous car i owned
Old Feb 17, 2010 | 08:25 PM
sirt_eg's Avatar
send me pics of those headers and exhaust.
Old Feb 17, 2010 | 09:32 PM
newkid2's Avatar
pics of the lowjack may want take it off your hands..also any more info about it
Old Feb 24, 2010 | 11:17 AM
pics will be up tomorrow damn ive been slacking lol.
Newkid2: i dont have any info on it because it came with a delsol that i bought 2 years ago. I know the guy had it connect to the ecu and when the ecu isn't being powered it has a back up battery to run it.
Old Mar 2, 2010 | 11:37 AM
pictures will be up tonight/tomorrow morning. with other parts that i found laying around
Old Mar 5, 2010 | 03:34 PM
Bump
Old Mar 9, 2010 | 02:29 PM
Bump
Old Mar 9, 2010 | 02:56 PM
David12's Avatar
doesn't the lojack policy cancel itself when you put it in another car? i was going to buy it and they told me if you where not the origional owner of the system or you didn't buy the car it was origionally equipped with, you wouldn't be able to use it
Old Mar 17, 2010 | 11:14 AM
not sure
Old Mar 25, 2010 | 12:59 AM
bump for pics
Old Mar 25, 2010 | 08:36 AM
bump bump
Old Mar 25, 2010 | 08:50 AM
1sickek187's Avatar
interested in the seats hit meup with a price. and how would i clean them? whats on them?
Old Mar 25, 2010 | 09:05 AM
donvito#1's Avatar
were u located want those sp wires
Old Apr 2, 2010 | 10:00 AM
located in ripon. pm me if you wanna pick them up
Old Apr 4, 2010 | 12:44 PM
Easter bump
Old Apr 6, 2010 | 10:26 PM
up up
Old Apr 7, 2010 | 10:49 AM
bump
