Built B18B
Old Dec 20, 2008 | 12:48 PM
tcbhonda's Avatar
Default Built B18B
Built b18 ls turbo long blockb18b block
darton sleeves 81.5mm
supertech block guard(just a little extra insurance)
eagle rods
supertech pistons 9:1 cr
cometic headgasket
arp head studs and rod bolts
entire rotating assembly balanced
block is line honed all oil passages de burred.
all machine work done by MPG race engines in highland park il. 1900$ worth
crank is nitrited
gsr oil pump
acl crank and rod bearings
golden eagle waterpump
gates racing timing belt
ls head (fully rebuilt and pressure tested)with valvetrain
Blue powercoated valve cover
will come with a 90-93 integra intake manifold modified for a later throttle body with thermovalve built in(aka any obd1 civic teg prelude etc etc.)
needs and few little odds and ends like a lower timing belt cover and the valve cover needs the rubber grommets.
you supply your own flywheel and front pully. i might have a stock ls flywheel i will toss in have to look for it
Motor was built for my DA but I sold the car and now its just sitting around. Never been fired. I am asking 3500obo.
Does Not Come with Turbo setup.
Trevor
Old Dec 21, 2008 | 01:54 PM
tcbhonda's Avatar
Default Re: Built B18B
bump. will take 3k
Old Dec 22, 2008 | 02:21 PM
tcbhonda's Avatar
ttt
Old Dec 23, 2008 | 10:24 AM
tcbhonda's Avatar
bump shoot me some offers on this motor i need it gone i need money for my b20
Old Dec 24, 2008 | 01:52 PM
tcbhonda's Avatar
Bump for a DARTON sleeved block!!
Old Dec 24, 2008 | 09:45 PM
Dev15Bizz's Avatar
will you sell just the block
Old Dec 26, 2008 | 12:35 AM
tcbhonda's Avatar
as far as block just bare block or with internals and no head?
Old Dec 27, 2008 | 03:14 PM
tcbhonda's Avatar
if you are within 200 miles of me for 3500 I will put it in your car for you. I am in Chicago.
Old Jan 26, 2009 | 10:30 AM
VTEC_PRODUCTION's Avatar
will you take 1700 for the complete bottom end? i dont want any other parts
LSvEKhatch
Aug 13, 2015 08:46 PM
Chris1521
Mid-Atlantic (Sales)
16
May 6, 2011 04:14 AM
hpc.aeroe.
Jun 18, 2010 07:03 PM
shivic
Jun 19, 2008 10:13 AM
