b16a block
Old Jun 15, 2010 | 10:29 PM
hrs-parker's Avatar
Default b16a block
Heres the run down. I picked this up planning to rebuild everything
specs:
b16a block 90k
oem crank
oem main caps
oem bolts
oem water,oil,tensioner all still attached
timing belt cover(no bolts)
mostly everything is still on there(thermo housing etc with oil canister in the back etc)
eagle b16 crank new
eagle b16 rods new
need pistons and rings
need a block guard if you plan to boost(or not)
all you need is a resurface and hone in the cylinders and its all good to go
650 firm
pretty clean as for the block
WILL TRADE FOR A B20 or B18
Old Jun 16, 2010 | 06:39 AM
hrs-parker's Avatar
Default Re: b16a block
bump
cleanazcoupe
Nov 30, 2009 08:14 PM
jdm_vtec
Mar 5, 2007 11:01 AM
sweet
Apr 21, 2003 06:57 AM
