Lighting HID/Xenon kits, Retrofits and Associated Topics
side marker issue
Old May 25, 2009 | 12:14 AM
6footmidget's Avatar
Default side marker issue
okay so i just installed my side markers today and they dont blink in unison, ive got one wired to the red and one to the green on my turn signal, when the turn signal blinks, my marker doesnt, so they take turns blinking and it looks RETARDED so how do i fix this? i want them to illuminate and blink with the corresponding signal, would that be black and red? or black and green?
Old May 25, 2009 | 09:08 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: side marker issue
You have each wire hooked up to the positive wire of each filament of your front corner/turn signal bulbs. You need to hook up one wire to the power wire of your turn signal filament (can't tell you which one, use a multimeter to figure it out), and the other wire to the ground wire or to body ground.
Old May 25, 2009 | 03:23 PM
okay ive done my searching and i just wired it how its supposed to be, just not how i want it, i wired one wire into the black (ground) and the other in green, the turn signal one and so now it wont turn on when my lights are on but it will turn on whenever i signal, is there any way to make it turn on AND signal?
Old May 25, 2009 | 05:55 PM
Community Builder
Yes, put it back the way you had it.
However, it will only flash at the same time as the signal when the parking lights are off. When the parking lights are on, the sidemarkers will also come on, but will flash alternately from the turn signals. That's just how it works.
To make it work like how you want it would take some complicated logic circuitry that would change the input the sidemarker gets depending on if the turn signal is activated or not, when the parking lights are also on.
Old May 25, 2009 | 06:24 PM
98civdx's Avatar
Master Detailer
^^ what he said they wont blink at the same time.
Old May 25, 2009 | 06:41 PM
well it looked kinda ridiculous alternating the way it did, but ill just leave it cause i cant afford to cut and soder any more wire, the wires already been cut cause of the parking lights in my headlights, thanks for the help though!
HONDRETTI
Jan 11, 2009 07:30 PM
dj theoretic
Jan 5, 2009 05:43 PM
Jameson
Apr 24, 2007 06:05 PM
hatch96y7
36
Dec 18, 2006 09:49 PM
chrisir19
Jul 21, 2003 09:14 AM
