Lighting HID/Xenon kits, Retrofits and Associated Topics
retrofit questions!!
Old Feb 8, 2011 | 02:33 PM
styles671's Avatar
Default retrofit questions!!
alright i got some projectors to retrofit my integra headlights but the problem is each of them are off different cars!
1 is from a mercedes amg and i dont know what the other 1 is for i got them for free so i couldnt pass them up, i know the amg use d1s bulbs and IDK about the other 1, both different in length and size
so my question is can i still retro fit it to my integra headlights?? can i modify the projector to make it accept the same size bulbs so i dont have to buy 2 different types? il post pics of the 2 projectors....
any input will help thanks!!!
Old Feb 8, 2011 | 04:52 PM
Blazin Si's Avatar
Loved
Community Favorite
Default Re: retrofit questions!!
Sure, you can still retro them. I'm not familiar with either one of those projectors, but it'd be a good idea to fire them up and see what they look like. Just about every projector has its own signature beam pattern and cut off step. Most of which can be modified in some way. I'd see what they look like first, then decide if you want to spend the time with the retro.
Old Feb 8, 2011 | 05:49 PM
styles671's Avatar
uhm can i shorten the space between the projector and the bulb? it has a big space between them as in space in the middle... thanks!
Old Feb 8, 2011 | 06:49 PM
Blazin Si's Avatar
Loved
Community Favorite
Why would you want to shorten the distance? To give them a more similar length? By adjusting the lens spacing, you'll either sharpen or soften the cutoff. By the looks of it, there's too much of a difference in size to make them equal in length and not adversely effect the cut off. You'll almost certainly have one projector out of focus by doing so. Literally, +/- 1 mm in spacing can make the cutoff fuzzy.
Also, if you change out one of the bulb holders to match the 2nd projector, you'll need to pay attention to how it seats. If the bulb is too far in or out of the bowl, that will also effect the beam pattern.
I'd personally buy another projector to match one of the two you already have. Either that, or retro the ones you have, but leave them as is. The important thing is the beam pattern and how it lights up the roadway. No one can see the projectors after they're in the car.
Old Feb 8, 2011 | 08:02 PM
e46civic's Avatar
The one on the right is halogen.
Old Feb 10, 2011 | 06:39 PM
styles671's Avatar
can anybody else say this?
Old Feb 11, 2011 | 06:42 PM
styles671's Avatar
ttt
Old Feb 11, 2011 | 07:27 PM
e46civic's Avatar
Its a 900X/ H11 base, its not the same as the D1S base on the left one. Halogen.
8dxhatchy8
Feb 7, 2011 01:02 PM
DC5toDC2
Jun 16, 2010 03:59 PM
Integra_Boi
Feb 3, 2003 06:43 PM
ih8danoles
Dec 8, 2002 03:10 PM
