Lighting HID/Xenon kits, Retrofits and Associated Topics
Question with my HID's
Old Dec 20, 2010 | 03:50 PM
z0mby's Avatar
Default Question with my HID's
When I run my headlights(HID's) my driver side light looks as if it is kind of fading a little bit. Could this be the ballast going bad?
Old Dec 21, 2010 | 08:33 AM
johnnykash's Avatar
Default Re: Question with my HID's
could be something like that possibly or it could just be a bad bulb. did you get that particular bulb dirty when installing it or anything?
Old Dec 21, 2010 | 08:56 AM
z0mby's Avatar
^Nah, they were working fine a while ago. Just when I follow like a pickup truck or something now it looks as if my driver side light is lighter than the passenger side. So I'm either thinking it's the bulb or the ballast going bad. Idk though.
Old Dec 21, 2010 | 11:57 AM
johnnykash's Avatar
hmmm ughh alright then,
what about checking to see if there aligned correctly, like on the same level?
Old Dec 23, 2010 | 12:08 PM
alphalanos's Avatar
switch the bulbs side to side. that will answer your question. If it stays the same you have a ballast/wiring issue. If the dim light changes sides then you need new bulbs probably.
Old Dec 23, 2010 | 03:56 PM
z0mby's Avatar
^Cool man, I'll give that a try.
Old Dec 29, 2010 | 01:41 PM
ruin's Avatar
did your kit come with a relay?? that could be causing your bulbs to go bad.
nObOdy65
Jul 29, 2006 04:45 PM
